Paging Macster (as well as others) What's the reliability of a modded turbo?
Thanks to everyone for all your input, and for the clutch advice, Macster... I tried to find out from the seller about the mods, apparently he bought the car 5,000 miles ago from the original owner and does not know who the shop was that installed everything other than it was in Atlanta, Ga...
the car is guards red and was originally from Atlanta if anyone knows of it.
I will be sure to closely inspect this car further...
call motorwerks racing in cumming GA (atlanta suburb) and see if they know it. they used that combo of stuff very effectively a number of years ago. if it was them the 650 claim is legit (they will have dyno sheets) and the clutch has definitely been replaced. also very reliable. that being said, I would still want a good shop nearby and a good relationship with them.
That kinda HP could be taxing the standard transmission. If it had the GT2 trans then it should be no issue. The GT2 trans is beefier, has internal oiling stup for cooling, and steel synchros.
Yes, GT2 tranny is marginally better (steel synchros)- but there is ZERO data that this power can damage the stock tranny. Yes you say "could" and "should" so you cannot be pinned down, but the gist is that you are bringing up nonsense. Likely another excellence article?
Or call some dealers in the area and see if anyone remembers the car. Often the Porsche techs know of various cars that are hot-rodded and know where the work was done or can give you a pretty good idea.
Sincerely,
Macster.
does anyone have any input on this?
Adam, first off the GT2 is not just maginally better. If you did your homework, you would know that the GT2 trans has a trans oil cooler, internal spray rails for better oiling, steel synchros, and gears on the input shaft are not pressed on. With that said, why do you think with the increase in HP that Porsche provided an upgraded trans. Don't you think if they felt the 996tt trans could take the additonal torque and HP I doubt they would have made the ugrade. Keep in mind if one states 650HP that is at the wheels, So in reality you are talking 765 shaft HP, 15% loss at the wheels, Sent an EMAIL to a Porsche trans specialty race shop yesterday. They are in agreement that this type of power without knowing the torque output could be taxing the 996tt trans. They suggested they had a way to upgrade the internals of the standard trans to accomodate, rather than spend a lot on a GT2 trans. It was confirned that the GT was better equipped to handle this power better.
Since you have nothing to back up your comment, I suggest you do some homework, before you try and contradict something that has been discussed with the pros. Using Excelence in your comment just shows the context of your thought process.
Say what?
