Spark Plus Terminal Nut
I took out the original factory Beru out and was about to put the new Bosch fr5 ldc in that I noticed they don't have a terminal nut. They have a threaded stud. Do I need a nut? The original Berus have a nut that can't be taken off. I tried screwing it off but won't turn.
Thanks,
--mm
Thanks,
--mm
While the FR5 were the original plug installed in 2001 and early '02's This is the incorrect heat range for the turbo and crappy pump gas. I strongly recommend that you install the Bosch FR6 LDC They will have the factory installed "nut"
