996 Turbo Forum 1999-2005
High mileage 996 TT?
Old 02-24-2019, 04:32 PM
  #331
MezgerTT
MezgerTT's Avatar
Originally Posted by J P Schnitzer
Clutch was original...btw, clutches last easy 100,000 miles. Anybody that tells you that a clutch only lasts 30,000 miles or something like that just doesn't know how to drive.
yup
Old 02-24-2019, 04:39 PM
  #332
MezgerTT
MezgerTT's Avatar
Originally Posted by T2
90k miles is just broken in to me.
T2
Yep
Old 02-24-2019, 05:02 PM
  #333
T2
T2's Avatar
I'm only on my second clutch, first one was replaced at 373k only because a bearing went and cracked the pressure plate, my only concern was fatigue at the springs, there was at least 80% friction material left, this car sees bumper to bumper traffic every day for long stretches.....just one data point
Old 02-24-2019, 10:30 PM
  #334
my04996tt
my04996tt's Avatar
You are really setting some records here.. A tt with 590k miles.. A clutch with 373k... All the best, keep going..
Old 02-24-2019, 10:53 PM
  #335
"02996ttx50
"02996ttx50's Avatar
agree re clutch life. i changed this one at about 90k and don't even remember why. now at 160k my goal is to live long enough to need to replace the clutch again. all my previous 911's have been "broken in" at btw 30 and 50k miles. this one took 100k.
T2's anecdotal reports are inspirational.
Old 02-25-2019, 12:32 PM
  #336
jayi836
jayi836's Avatar
Good to know about the clutch lifespan seem to be over engineered like the rest of the car, if not drag racing at each traffic signal should last forever.
Old 02-25-2019, 03:54 PM
  #337
rael
rael's Avatar
Sorry if this has been covered but are your coolant lines pinned or welded?
Old 02-25-2019, 04:06 PM
  #338
jayi836
jayi836's Avatar
T2- how about the hoses, all original? ever flush the power steering fluid and replace the struts?
Old 02-25-2019, 05:43 PM
  #339
T2
T2's Avatar
We welded coolant lines when engine was out, they were not leaking, it was preventative
I've replaced ps pump and one hose, for the annoying squeal, TSB on that.
Old 02-25-2019, 05:44 PM
  #340
T2
T2's Avatar
It also has KW Clubsport suspension, GT-3 sway bars, adjustable drop links
996TS (06-06-2022)
Old 02-25-2019, 05:58 PM
  #341
Dock
Dock's Avatar
We welded coolant lines when engine was out, they were not leaking, it was preventative.
Was that when you pulled the engine at 383k?
Old 02-25-2019, 09:43 PM
  #342
T2
T2's Avatar
Yes Dock, 383k, no leaks prior, just good practice while engine was out
Old 02-25-2019, 10:48 PM
  #343
Dock
Dock's Avatar
No doubt that pinning or welding is not a bad idea if the engine is out. I just think that a 383k mile data point with no leaks is noteworthy.
Old 02-25-2019, 11:53 PM
  #344
Carlo_Carrera
Carlo_Carrera's Avatar
Received 2,232 Likes on 1,441 Posts
Originally Posted by Dock
...I just think that a 383k mile data point with no leaks is noteworthy.
Why? I have seen cars with 20k miles blow pipes. Mileage has nothing to do with it.
Old 02-26-2019, 12:16 AM
  #345
Dock
Dock's Avatar
It's a data point.
Quick Reply: High mileage 996 TT?
