Whirring noise from front end at 110+
I noticed that I get a whirring noise from the front end of the car when i go over 110 mph. It sounds almost like the alert you can program into the NAV when you go over a preset speed. I have a feeling it is the front diff since the tires on the car aren't the ideal sizes. They are 26.0" front and 26.2" rear. I think the stock sizes have the rear's about .3" smaller than the fronts. Could it be anything else or should I just start shopping for new (different sized) tires?
Professor of Pending Projects
I will let others that know more on the subject chime in... but you are hurting your front diff by running the wrong tire size... could be just that.
Better do some research on this issue....it was just dealt with about a week ago with discussions on correct ratios between front/back and the fact that you can't always count on what's stamped on the tire to be exact....there's a formula as well as some helpful hints in another discussion...do a search..I can't remember the name of the discussion....but it had a bunch of good info in it. I'm sure someone wil chime in with the link...
Yeah, i read that discussion which made me think that was the problem. The general consensus was to keep the tires within 3% of each other. No one ever said which way though (I could assume rearsmaller than front, but you know what assumptions make!). They are still pretty close (.2" different front/rear, .5" different from stock) so I wasn't sure if that would cause much of a problem. I do notice that my ABS will kick in just slowing down to a stop sign sometimes. Is it a simple procedure to eliminate the AWD until i get new tires, considering there is $2K worth of tires on the car now (Pzero Rosso's)?
hmmmm....tell us the actual sizes of the tires you have on. I agree with Tom, not likely this is it....but the description of the sound is strange. It sounds like an alarm? Get the codes read 1st.
The fronts are 245-35-19 which tirerack states is 26" diameter, 800 revs/mile
The rears are 295-30-19 which tirerack states is 26.1" diameter, 798 revs/mile
I was thinking about trying to disconnect the front drive if it was a simple process to try to eliminate that possibility. Is there a DIY someplace?
As far as the noise, it is definately mechanical, it just sounds similiar to the alarm in the Nav system. I have a durametric on order to see if there are any codes. Had the car read about 1-2 months ago when I bought it and nothing came up, the first time it went over 110 was when i heard the noise so I believe it has always been there.
Have you checked all panels/covers/etc? Perhaps something is loose/flapping at 110mph and causing buzzing or vibration.
GL
A
Ooh, that could be it!! I'll throw a piece of tape on them and give it a shot....much easier than trying to disable the AWD.
One quick question.... I thought that the front tires were supposed to be .3" BIGGER than the rears. In my case, the front tires are .1" SMALLER than the rears. Is that still ok???
The tires on the 996TT should be the same. It is commonly stated that a difference of UP TO 0.3" is acceptable. However you should target 0.0.
Now the 997TT does have a designed difference, but not the 996
