Rear 330mm x 28mm Rotor Spec
Does anyone know or have a rear rotor off to measure (reasonably accurate) the backspacing or offset? The back-spacing would be from the wheel hub surface to the back side of the rotor (= offset + 14mm). I specified the 330mm rotors in the title, but I'm not sure if this is the same as the 350mm x 28mm PCCB rotors. Thanks in advance!
