Plugs, coils, and what else?
2005 TurboS 43k miles owned 8 years
Im taking my TTS in later this year for service. Just preventative maintenance to replace plugs and coils. This set has about 15k miles on them. I would like to know what else I should consider replacing while it’s there for service?
On my M5 I usually replace the fuel filter, MAF, O2 sensors, and Hall effect devices like cam position sensors during major service. Is there any benefit to doing these items on the TT or should I just have the basics done?
thanks for any input
Since the car is almost 20 years old I would do this full 60K service.
That would be spark, plugs, coils, air filter, cabin filter, transmission oil, front differential oil and fuel filter.
996-turbo (06-13-2024)
Here’s a comprehensive diy pics etc for you to review….
http://bd8ba3c866c8cbc330ab-7b26c6f3...tenance_R1.pdf
Thanks. I’ll add the fluids and consider the full 60k mile service. I had the 30k mile service done in advance and might as well use the 60k mile service as a go by. Ivan probably do the MAF and O2 sensors myself.
Maf and map sensors are easy ones. The 02 sensors are fun to get out……torch time or an inductive heater to get 5hose bad boys off at least on mine !
They do screw in and out but sometimes they stick so applying a little heat to the bung they are screwed into will help ease them out.
autobonrun (06-11-2024)
Wouldn't be a bad idea to do a boost leak test and replace the #16 check valve
There are quite a few check valves that should be replaced up there. Perhaps changing out the F-pipe hose to a silicone one before the oem one splits if you haven't already. Apparently this is common.
Have them check the diverter valves..They should hold 20 psi of vacuum. You can just compress them by hand and plug the nipple with your finger and see if they stay open as a quick test but mine were able to hold 20 psi without any leaks.
autobonrun (06-12-2024)
If a manual? The 90K service interval for gear oil is ( to me ) vastly overdue also. If you like your transmission. I'd say 45K miles is just about right to ensure smooth shifts and eliminate "notch-i-ness". Only thing mentioned that from experience I don't see as "regular maintenance" items? are the 02 sensors. Do they go south? Sure. But that is the time to swap them not premptively and yes, they can get "stuck"!
That said. Everything that wears out can be replaced, and no one could fault you for doing it "early".
Most independent mechanics recommend changing the O2 sensor before the catalytic converter at around 90,000. The one after the catalytic converter will last longer but since you’re in there might as well change both on both sides.
How about the servicing the front wheel bearings and half shafts? Could they use some attention? I just drove 500+ miles back from the Porsche Parade and I had a rhythmic noise coming from the front of my car on the highway. It sounded more "mechanical" than simply tire noise. My car has 61K on her, and I don't see any records of front diff service.
Thanks,
Steve
Thanks,
Steve
