To Intercooler or Not?
At what point of the mod sequence does it make sense to consider improved intercoolers? Assuming the basic mandatory tune and exhaust up to 500+ HP have already been done. Strictly for track usage, or worthwhile for the occasional spirited drives on streets and highways? Seems like an easy bolt-on with no downside other than the cost. Lots of posts on intercoolers, but nothing seemingly definitive.
I'm planning to upgrade to 997 GT2RS intercoolers while my motor is out. My only other power mods will be exhaust and tune. They seem like a no-brainer to me.
Originally Posted by spooltime
(Post 16036931)
"spirited" street drives aren't *typically* what contributes to significant heat soak.
tracking, will though.. and quickly. |
At any point. You'll see benefits right away from a quality intercooler setup.
I noticed it right away in logs and feel after doing Kevin's ZC16 turbos.
After a leak test, tune & exhaust, it would be my next move along with inlet pipes while the engine's out. Do the plugs too while the bumper is off. Here's some more: https://rennlist.com/forums/996-turb...996-turbo.html |
Originally Posted by 911mhawk
(Post 16037316)
After a leak test, tune & exhaust, it would be my next move along with inlet pipes while the engine's out. Do the plugs too while the bumper is off. Here's some more: https://rennlist.com/forums/996-turb...996-turbo.html I run Kevin's ZC K16s with his tune and a europipe (along with clutch kit). My car post this originally had the stock intercoolers and I immediately noticed the flat spot that comes in the rev range with cars on stock coolers. Swapping these out for 997.2 coolers immediately fixed this and the car pulls hard. I mainly use mine on weekends and for track work. |
Originally Posted by 1q2w3e4r
(Post 16037994)
Originally Posted by Dock
(Post 16038492)
At what RPM?
Not sure that I'd describe mine as a flat spot because it's the kind of thing you may not really notice until after you use the superior part. I changed to a 100 cel Milltek and Evoms inlet kit and fueling and FPR at the same time, then added the ICs but I'd guess you'll notice butt dyno verifiable improvements with just the ICs and a tune/exhaust, especially in hot weather and track/heavy load runs. |
Are non-RS 997.1/.2 (is there a difference between the two?) intercoolers a worthwhile upgrade over the standard 996 units?
The ones you mention would be an upgrade, as are X50 ones but you want these:
997-110-639-71 997-110-640-71 Ryan/Greg/Gina are great to work with: https://www.sonnenporscheoemparts.co...er-99711063971 I have stock X50 ones in perfect shape, PM offer |
(Post 16038660)
...I'd guess you'll notice butt dyno verifiable improvements with just the ICs and a tune/exhaust, especially in hot weather and track/heavy load runs.
Originally Posted by Capt. Obvious
(Post 16038676)
(Post 16038835)
Any improvements in horsepower and torque or an improvement in power delivery (or all of these) based just on the addition of the intercoolers?
On hot days in high load/boost scenarios, you'll pull less timing and get more power. I'm not sure how much of a difference it would make for around town stuff since I noticed it most in gears 3/4/5, at which point you're moving at 70+ |
(Post 16038835)
It's worth it on even a mildly modded car. |
