AutoTalent - Giro Disc Racing Brakes and Technology - Rotors and Pads
Former Vendor
Matt@autotalent.com
Girodisc Front and Rear 350mm 2-piece Rotor Upgrade for Porsche 996 Turbo
The Girodisc system is a direct replacement for the OE disc with the addition of our provided caliper spacers and longer bolts. Our rotor is slightly larger than the OEM rotor at 350mm versus 330mm providing greater braking force and cooling capacity.
The central hat section of our rotor is made from strictly U.S. sourced 6061-T6 aircraft specification aluminum. The disc is made from our own proprietary cast iron, poured in the USA and machined from start to finish in house at Girodisc. The rotor utilizes a curved vane design, developed in racing to act as a centrifugal pump to force cooling air through the disc.
The rotor and hat have a floating mount system, which utilizes 10 high strength alloy steel drive pins, manufactured by Girodisc in the USA to our own specifications and cadmium plated for a long lasting corrosion resistance. These pins take the load from braking actions while maintaining the axial and radial float between the hat and disc. The pins are secured by grade class 12.9 screws with hardened washers. In order to keep the rotors from making noise when cold, the pins are mounted with anti-noise spring washers on the rotor side which allow the rotor to grow with heat expansion but eliminate the rattle and noise associated with floating rotors. This float also allows the rotor to self center between the pads.
Once the Girodisc system is in place, simply replace the cast iron rotor when needed.
Sold/priced per pair
Girodisc S/S Front Pads for Porsche 996 Turbo/C4S
The Girodisc S/S or "street/strip" pads represent the ultimate in high performance brake pads.
The semi-metallic compound maintains a consistent coefficient of friction from 0 to 1000 degrees making them an ideal option for people that are looking for a dual purpose pad that will work well on both the street and the race track. The formula has very little compressibility ensuring a very firm pedal and immediate bite which has made the S/S pads a favorite among people who autocross and those who demand the most out of their street cars. Inevitably these will dust more than our Magic pads however with the addition of our anti-noise shims that come on every set of pads they will not make any noise if they are bed in properly.
Girodisc 2pc Rotor Ring Replacements - Porsche 350mm
Need new rings for your Girodisc 2pc rotors? We got them.
How to Place Your Order:
Phone Domestic: (855) 973-2757 X 123
Phone International: (310) 231-7800 X 123
E-mail: Matt@AutoTalent.com
Website: www.AutoTalent.com
Payment:
Attachment 1345656
Installations:
Feel free to visit us at our facility in Los Angeles, CA.
We install everything we sell.
19143 S. Hamilton Ave
Gardena, CA 90248
Shipping:
All orders are shipped via FedEx, UPS, USPS and Pilot.
International, Hawaii and Alaska customers: Please contact us for the best quote possible.
Hours of Operation:
Monday through Friday: 10AM-7PM Pacific Time
Saturday: By appointment only
