Disabling alarm
Disabling alarm
Is there a way to lock the doors without enabling the alarm?
I get the double beep (or maybe single. I disconnected the horn) when locking and the alarm goes off randomly.
I'd rather just disconnect the alarm completely. Is this possible?
I'm not about to go to the dealer and drop a bunch of money on something I have no need for.
If you are getting a beep it means there is fault in the alarm sensors (e.g., center console, door, glove box, etc. left open). If you are getting double beeps, there is a defect in the central arm system.
You can disarm the interior IR detector, but I don't know how to disable the entire alarm system.
I appreciate the info.
Have searched the threads up and down and there is lots of info there, just nothing to disable other than locking and unlocking and it should lock 30 seconds later without the alarm.
As mentioned above, a single beep when locking with the fob indicates a fault. Often it's the radio alarm wire if the center stack has been modified, or the arm rest cubby.
Can't say about locking with the key... I never lock or unlock my car that way.
As for disabling, there might be a way to do it with the PIWIS tool, by perhaps "removing" the alarm module from the configuration. But the chances any given Porsche tech would know how to do it, even if was possible, are fairly slim.
Are you sure? When I lock my car with the key (which I always do because my fob doesn't work), if I turn the key clockwise once the car locks and I get no beeps. If I turn the key clockwise twice, I get a single horn beep. I know nothing is left open and the alarm works properly.
Not positive, but I believe when you perform that action, you are purposely disabling the inside IR sensor. This is typically done when you leave someone or a pet inside so as not to activate the inside sensor.
