Pacific Raceways new surface
So very cool! What was ahead of you?
Looks good. How's the grip?
Looking like a blast Mark! Is that a 997 GT3 Cup you are chasing?
It's incredible when dry, but it rained at this outing and with fresh asphalt oil comes up to the top so it can be a little sketch until it dries out well.
Yea, it's a ton of fun as you know!
Wish I had that excuse, it's a stripped 6GT3 w/a built 3.8 on slicks and a guy with more laps than I've had cheeseburgers.
Those were also the first laps I had on new tires
The new surface is wider in several areas, off camber 3a has more room on the outside and the ripples in B are gone. 5a braking zone is significantly smoothed out and wider with a later apex, giving more speed and a need to brake for 5b. The line has definitely changed and you're carrying more speed in several areas, making almost any off-track a potentially big deal. Also, 1, 7 and 9 are high speed where you'd better not lift.
150 +/- 5 if I keep my foot in it on the straight. I typically back off a little on the straight and go in about 130-140 since the prize $ is horrible at DE and braking from 155>75 takes it's toll on rotors, especially when the next braking zone is one from 120>40.
Could probably hit 160 before the brakes but the most I've ever seen is 157 on a log file,
He is fast for sure, normally seeing you get everyone out of the corners in the videos is a little shocking seeing him pull away is shocking for a mighty 6TT!
