Replacement Part Help: "Rocker Panel"
I need to replace the outer "rocker panels" on my 996TT. I'm having trouble locating the part. Closest I could find on a part locator was 996-503-963-02-GRV and 996-503-964-02-GRV, but the images I'm finding are all partial and don't seem quite right. The part I need to replace is grey in color, not body color, and has the "snap in" tiny rubber mud flap. Both of mine appear to have been cracked by a careless jacking of the car; they are cracked adjacent to the jackpoints in the rear. On the driver's side, the damage is all in-board; on the passenger side, the cracking is visible even from a distance.
TIA for the help folks.
I purchased replacement sill covers from Sonnen. Pretty simple to do if you have a low profile ratchet, otherwise you may have to remove the front tire.
996 504 363 00
996 504 363 00
Thanks for all the replies and help. The team at Sonnen are great and provided this info:
996-504-363-00 LEFT
996-504-364-00 RIGHT
These are both satin black. These fit 996 Turbos that do not have the factory X1AF Aero Kit.
996-504-363-00 LEFT
they will fit the aerokit cars as well. aerokit are just painted to match
I ordered mine from Sonnen last Friday...
Order Content
Part Number
Part Name
Price
Quantity
Total
996-504-363-00-01C
Trim For Door Sill
$143.23
1
$143.23
996-504-364-00-01C
Trim For Door Sill
$143.23
1
$143.23
Part Name
Price
Quantity
Total
996-504-363-00-01C
Trim For Door Sill
$143.23
1
$143.23
996-504-364-00-01C
Trim For Door Sill
$143.23
1
$143.23
Subtotal:
$286.46
Shipping (FedEx Ground U.S. Shipping - FedEx Ground Home Delivery):
$89.09
Total:
$375.55
$286.46
$89.09
Total:
$375.55
Get all new mount tab seals. If any old ones stay in place leave them. Putt any new ones on the tabs not in the holes. Get curved jaw forceps to fish the ones you push into the rockers out. Two people make lining up the tabs and snapping them in much easier.
AND, be sure you pull it off/reinstall it in a single vertical movement - I did not and buggered one by breaking the little tabs off.
