Need TT Spoiler options
My spoiler hydraulic pump went out and I need to find a solution for my spoiler. Currently the OEM system and parts are removed and just have the 2 holes in the deck.
Options that I am aware of are below, but I don't know what I don't know so if there is something else please chime in. 1- replace with new factory parts 2- reinstall OEM rams and put at a fixed/manual wing 3- install a deck and fixed wing, will most likely require paint/bodyshop 4- unsure if this is possible, but can the TT deck be used with a fixed wing? 5- ???? open to ideas update- 6- Ebwerks manual kit http://ebwerks.com/models-996997.html |
5- ???? open to ideas No idea what the cost is or turn-around time. http://ultimatemotorwerks.com/rebuilding.html But your failure was the pump, not the cylinders?? |
Originally Posted by ipman
(Post 15856570)
My spoiler hydraulic pump went out and I need to find a solution for my spoiler. Currently the OEM system and parts are removed and just have the 2 holes in the deck. For reasons I won't get into, the eRam kit is NOT an option.
Options that I am aware of are below, but I don't know what I don't know so if there is something else please chime in. 1- replace with new factory parts 2- reinstall OEM rams and put at a fixed/manual wing 3- install a deck and fixed wing, will most likely require paint/bodyshop 4- unsure if this is possible, but can the TT deck be used with a fixed wing? 5- ???? open to ideas Or plug the holes and leave it as is. |
Originally Posted by pfbz
(Post 15856618)
Isn't Kevin at ultimatemotorworks now rebuilding the oem rams? And if I recall, after rebuilding them, they are easily serviceable with replaceable seals...
Damn. I guess that explains why he didn't respond to my inquiry (no worries, Kevin!). ;)
I have mine at ta fixed height w/ CF lightly larger wing.
I'm sure you can piece together that ebay kit for cheaper |
Be patient and wait on Kevin.
Originally Posted by Carlo_Carrera
(Post 15856667)
RennKit erams are really really good.
Originally Posted by "02996ttx50
(Post 15856648)
If everyone could DIY everything..
Most regular folks wouldn't know how to make that bag of bolts. |
Originally Posted by TommyT
(Post 15858150)
If you plan on keeping the car then go for Dave's Rennkit electric rams. Never look back.
