ABS PSM Fault 4440 Steering Angle Sensor HELP!!!
Hey everybody! I have a new to me 2001 996TT. I bought the car knowing it had this fault thinking I could fix it. I have the newest Durametric and the code 4440 comes up. I have the ABS and PSM light on and my ABS doesn't work due to this I think along with PSM i assume. I have tried to use the Durametric to calibrate the steering angle sensor with no success. I am now trying to troubleshoot to see if in fact the sensor is bad. I cannot find a diagram to tear into the steering column to find the plug to test the terminals. I do have the testing procedure from the workshop manual but thats about it. This has been very frustrating as I like all things to work correctly and it's gotta be fixed. I appreciate anyone's help!
There has to be a procedure out there for removal and replacement in a workshop manual somewhere. I don’t want to take my wheel off unless I have to. I’ve taken the plastic cover off to get into wiring but before I go any further and do unnecessary work I’m hoping someone can help.
No I haven't been able to find a solution. I have scoured the web looking for a workshop procedure with no luck. I've found a sensor testing procedure but no information as to tear down the steering column to get to the sensor. I have found new steering angle sensors for 600 which is fine to get this fixed but I'm reluctant to go in there blind. I just drive it as it is for now but I have no PSM or ABS. I'd rather not pay a shop to fix this when I know I am capable. Although I have been considering it lol
Unfortunately I haven't. I've posed this question on all forums with a 996 turbo section and haven't found the answer. Since I am done driving for the winter, I'm going to pull the steering wheel off and dig in until I find the sensor. I'll test it, as I have found a description as to diagnose a sensor failure or wiring problem. All I was hoping to find is a diagram as to where the sensor is and how far I need to take things apart. I will update with what I find so if someone else has this problem it may help.
Started having the issue after a dead battery and battery replacement.
I've cleaned the MAF, replaced the brake pedal switch, and tried calibrating the steering sensor w/ Durametric
ABS and PSM lights always on and the only code I get is 4440.
