996 Turbo Forum 1999-2005
So if you have a Tune - can you use a stock clutch
Old 04-11-2019, 02:53 PM
g-50cab
g-50cab's Avatar
Default So if you have a Tune - can you use a stock clutch
So have some clutch slipping issues - 44K miles 2003 Turbo with a softtronic tune.
Had the car leak tested - holds a .9 - 1.0 bar boost - so it has some legs
I've done some searching - seems most on this site are saying go with the Sachs 2.5 or something from Kevin. My mechanic is saying I should stick with stock. I track the car - some autocross - although the last autocross I could smell it burning. What says the braintrust?
Old 04-11-2019, 03:02 PM
Dock
Dock's Avatar
Talk to Kevin.
Old 04-11-2019, 03:03 PM
s65e90
s65e90's Avatar
Waste of money going back w/ OEM, especially with a tune and your intended usage. Go with the Sachs 2.5. 764 PP and 098 disc. Do the gt2 conversion while in there.
17ram2500 (12-14-2023)
Old 04-11-2019, 05:35 PM
Road King
Road King's Avatar
My car came with a new stock clutch, has held up just fine over the last 10K miles with a 1 bar tune. That being said, when it done, I'm going with that Sachs, it's a no brainer.
Old 04-11-2019, 05:47 PM
bansasn
bansasn's Avatar
I have Kevin's tune with a stock clutch. The clutch was replaced a month prior to tune. The stock clutch held up just fine over the last 11K miles. Done two Autocross within those miles. For sure will call Kevin up when it's time for a new clutch to see my options.
Old 04-11-2019, 09:44 PM
docwyte
docwyte's Avatar
I have Kevin's tune with my stock clutch. But when it goes bad I'll be definitely be calling Kevin and getting his upgraded package
Old 04-12-2019, 01:00 AM
"02996ttx50
"02996ttx50's Avatar
my old girl is 575 rwhp w its 2nd clutch - a 160k mile car. the last one lasted 90k miles and i only swapped it because the trans bearings turned to mush. it was time, and my dmfw even looked ok. swapped it anyway.
stock oem sachs with the solid unsprung 996gt2 disc will last another 100k miles. unless you burn clutches. i use the clutch to shift gears even even then i usually double clutch.
old habits die hard, and people like to buy stuff they don't need. 2.5 sachs - as is it colloquially known as - is the next "upgrade". but that's just with the 764 added. whatever.
Old 04-12-2019, 09:35 AM
autobonrun
autobonrun's Avatar
Maybe you will, maybe you won't. My stock clutch slipped with a tune. It didn't slip with the tune off. I'll leave it at that. Discussion in this link.
https://rennlist.com/forums/996-turb...d-k16-car.html
Old 04-15-2019, 12:19 AM
ipman
ipman's Avatar
What are the benefits of going to the 2.5 Sachs as many have? What do you gain/lose? If your car has a tune and the rest is stock, the stock clutch should have 500hp. I know the accumulator is a weak point on the stock clutches but it is not expensive or hard to swap when needed (appears, I have never done one).
I need to call Kevin again but I think mine has a tune as I can see 1.0 and occasionally 1.1/1.2 and I am on a stock clutch.
Old 04-15-2019, 02:11 AM
Kevin
Kevin's Avatar
The stock clutch will last a certain amount of miles until it doesn't. The Sachs 764 pressure plate will offer longer life especially if you decide to track or auto X your car.
Here is a good gallery of some great clutch kits..
http://ultimatemotorwerks.com/clutch.html
996TS (03-30-2022)
Old 04-15-2019, 10:18 AM
993GT
993GT's Avatar
stock will typically hold if the clutch is in good shape, won't last forever as Kevin has said but can certainly work on a shorter term...duty cycle will determine timeline
the 2.5 clutch is a 'household name' of clutch upgrade around here but the big aftermarket names have some great products too
have roughly 100k km on my Spec setup currently but will be changing up to a factory 7'2RS/8lb f.w. and Clutchmaster fx350 clutch shortly (fairly aggressive setup.... D.M f.w. + fx250 would be a great setup for most)
Old 04-15-2019, 11:04 AM
ipman
ipman's Avatar
Thanks for the input, I am learning more about these every day.
Old 04-15-2019, 01:38 PM
2fcknfst
2fcknfst's Avatar
Received 3,852 Likes on 2,934 Posts
Originally Posted by Dock
Talk to Kevin.
+1, +2, +3... Love his clutch.
Old 04-15-2019, 07:27 PM
911mhawk
911mhawk's Avatar
Talk to Kevin.
+4 or whatever, his kits are complete with small parts and no guesswork. Given that you track and autoX, consider doing a cooler too if you haven't already. The GT cars come with coolers for a reason.
Old 04-15-2019, 08:44 PM
docwyte
docwyte's Avatar
Hmm? Are you talking a transmission cooler? Definitely no need in autox for that and arguably not for the track it just doing DE's
Quick Reply: So if you have a Tune - can you use a stock clutch
