Which turbo upgrade for track???
Hey all,
im looking for some hp improvement (maybe 600 hp at crank) with being totally safe for internals. I need something smooth with great response and dependable for track environment. No sudden spooling at the wrong time. Main application will be for track so I will need a tune as well.
Im looking for a nice long flat power band and something without any lag.
there are so many choices out there, I’m having a hard time figuring out what to get. I’m thinking about a k-16 platform.
I am also not sure about which exhaust I want to go with. The ones I like so far in no particular order are Kline, speedtech, eb works and unobtainium. Leaning towards the first two due to price/availability.
Main in thing is that this car will likely see 30+ track days a year so these things will need to hold up to that kinda of sustained intensity.
Geoff, feel free to email me or call. My Stage 2A Billet Zero Clearance turbochargers are designed for the track. You can couple that with my 3.0" race exhaust and most likely a clutch kit and you'd be set.
What else is on your car. Looks like you have no exhaust yet so is it even tuned? I'd start with exhaust, tune, intercooler and intake piping before upgrading turbos. Also fo all your suspension, brakes and wheel/tire upgrades first. The power is not what going to drop your track times until you do the rest of this first.
To answer your questions though, a billet k16 with clipped turbine wheel would be fine for your needs.
Your comment on lap lap times is spot on! I’m very excited to see the improved handling characteristics!
Attaching a a few pics...
996 GT3RS front uprights
What size tires will you be running. Note for the gt3 master, if you plan on wanting psm to work at all you'll need to do add a proportioning valve on one of the lines. Something I've been working on awhile to fix the psm problem with the gt3 master and we got it to work.
On the intercoolers, I hope you arent talking 996 gt2 because they arent very good. And get 997 gt2 rs and they are decent but still way better options. I run srm 4.5 inch myself.
How about brake cooling, what have you done there?
While there are out I'd strongly suggest changing the rear subframe bushings to solid bushings.
Subframe mounts done. Not sure what version of Intercoolers they are. I figure they’ll be an upgrade from stock. Basically as I understand the brake system, getting larger rotors will dissipate more heat than the stock brake system. I think with the intercoolers and brakes I am getting an excellent price and that helps a lot since there is a lot of upgrades going on. That said, I’d be interested in hearing about what you recommend.
Well at min add gt3 front ducts and 997 turbo rear ducts for the brakes. They are 60 bucks total. Like said with the gt3 master you are going to have psm/abs failure issues unless you just pull the plug from the psm pump and run with no psm at all 24/7.
Like said, if they are the 996 gt2 intercoolers, they arent really much better than stock. If they are 997 gt2 rs they are much better.
Back to tire sizes. What are you running?
If doing turbos are you planning on upgrading injectors? If you arent, doing turbos is not even worth it.
Have you pinned or welded the coolant lines? Those are very very very important if it's going to be a track car.
^ yeah we pulled the engine to address everything.
Wheels and tires are on the way. Order Nitto nt01 235/40/18 and 315/30/18 wheels much lighter than stock.
Well I can tell ya that eventually you'll want bigger tires in the front forsure. Most of use big track setup guys run 275/35/18 up front and 335/30/18 rears.
Easier setup to fit is a 265/35 and 315/30.
You'll have understeer issues with 235s as well as abs coming in earlier.
You have the wrong front uprights if you are planning to use 380 brakes. Can be made to work but requires adapters. Porsche makes 380 versions of those exact uprights. You will need rear matching wheel carriers also. Without the rears, your roll centers will be completely mismatched as you can see the drastic difference in the upper and lower pick up points on the rear carriers in the pic below (RS carrier on the left, TT/GT3 on right) Do your research as it is very easy to do it wrong and spend a lot of money without seeing tangible benefits. There is a lot of misinformation out there. Good luck with the build and enjoy the car safely!
