2004 Rogue Cupholder Question
Hi all - my 2004 TT cab has been lonely in the garage for a while, so I went out to visit it this morning. For some reason I decided to open the in-dash cupholder (the kind that slides out with 2 cupholders above the PCM). Out of the blue, the faceplate popped off. I took a look at it and it doesn't appear anything broke off, so I'm not sure why it decided to eject itself. There are 2 tabs that slide into slots and a small piece that looks like it fits into the teeth of a small gear.
My question is - do I glue it back on now? I can still open and close the actual cupholder but it looks terrible with the faceplate off. I don't want to glue it on and then realize it needs to be able to move when it opens/closes. No way I'm spending the cash for an OEM replacement for what is a terrible design in the first place. I searched and read plenty of threads but none about specifically reinstalling the fascia. Any ideas? TIA, Todd |
It should snap back in with the gears aligned. |
This is a common issue. It most likely broke, and you can't just snap it back on. There are some aftermarket faceplates, but they don't have the little cup icons on them. Note that they cups detail the bigger and smaller cup holders, which is cool.
You can buy a new unit and slide it in. I don't remember it being very expensive. |
Originally Posted by TheKane
(Post 15681820)
Found it... 996-552-183-02-01C with a list price of $362.
https://cimg1.ibsrv.net/gimg/rennlis...c703286eee.jpg |
$300+ is nuts. Even worse - $1900 if it is in leather!!!!
I'm going to play with mine to see if I can fix it. The location is terrible anyway, and it seems like the faceplate should snap back on. It is definitely way overengineered. |
Originally Posted by leftlane
(Post 15684030)
Mine just popped off one day when I went to close it. I use mine every day so I thought that kind of weird. I found a video on youtube that explained the whole disassembly process the guy in the video had a different problem than mine did but I was able to fix mine by replacing a plastic that broke with a metal one I fashioned out of an old drill bit. here's the video: |
Where can you get a repro front piece? I've never seen one for sale, even if it doesn't have the little cups on it.
(Post 15680318)
Right below the two central vents...
Originally Posted by 2fcknfst
(Post 15685290)
All years?
Originally Posted by T Kono
(Post 15685470)
All years?
All 2002 and subsequent year Turbos have cup holders standard. |
yea, i dont think they became available till the glove box was in 2002
