996 Turbo Forum 1999-2005
External wastegate headers w/EBC vaccum line routing. Help!
Old 02-15-2019, 01:40 PM
lb4lb911
5th Gear
lb4lb911's Avatar
Default External wastegate headers w/EBC vaccum line routing. Help!
I have installed a set of external wastegate headers attached with tial 44mm wastegates. Wondering what the proper way to hookup the vaccum lines. I have a good Idea but want to reconfirm this is correct.
Ive hooked up the top port of the tial wastegate to the existing line that connect straight to the COM port on the electronic boost controller’s solonoid valve. (This line was connected to my internal 1bar wastegate).
the side ports of the tial are CROSS connected to the NC port on the Electronic boost controller’s solonoid valve and Y-Pipe. Do these tial side ports need to be closer to the turbos or will they work fine routed to the Y-pipe? I do not have a dedicated fitting mounted on the k24/18g turbo housing for side ports.
NO line on the electronic boost controllers solonoid valve remains open.
Anyone with experience in this setup please chime in. Would love to get clarity and have my car dialed in.
Old 02-16-2019, 03:16 AM
32krazy!
32krazy!'s Avatar
internal wastegates on the 24/18? those will have to be welded shut
Old 02-16-2019, 12:00 PM
lb4lb911
5th Gear
lb4lb911's Avatar
I have locking rods to keep them closed.
Quick Reply: External wastegate headers w/EBC vaccum line routing. Help!
