Failure Oil Level Indicator Message
When I first bought my Turbo I too thought the e-dipstick was stupid. But now with years of ownership I like being able to check the oil with just a flip of the wand on the steering column. I do wish Porsche had also installed a conventional stick as a backup
I'm throwing up a link to Powdrnhound's original thread on the dip stick conversion and info on part numbers...
https://rennlist.com/forums/996-turb...onversion.html
InSaNiTy42 (01-04-2020)
You can do this mod by partially lowering the engine a few inches. I listed all the required parts a few years ago in post #8 of the following link:
According to the Sonnen diagram, I should order #s 15, 16, 17,18 and 19. #s Number 15 and 18 are different part #s from yours, and Sonnen indicates that filler tube 996-207-016-70 and seal 999-707-285-40 are incorrect for a GT3 and that I should order filler tube 996-107-150-59 and cap seal 996-107-336-00.
What do you think?
You need #11, 12, 13, 14, 15, 16. You may not need 0-ring (#12) which I think is part of the cap #11.
Thanks PH!
What do you think?
What do you think?
I ordered the parts from your list...thanks! Do you remember if the metal guide tube inserts into the Intermediate piece casting or does it free-float in the filler tube?
Thanks!
