Elephant Racing strut hat monoballs
Hi All,
I just ordered a set for the front and rear strut hats. These basically replace the rubber bushing with solid monoball. Has anyone else ever ran these? How was your experience? Thanks!! https://cimg9.ibsrv.net/gimg/rennlis...02f18a658d.jpg |
Not familiar with the elephants, I have been on these GMP EVO camber plates. Unless you are planning on mono balls on the other pick up points I don’t think it would be worth it. Becomes a slippery slope quickly.
https://cimg7.ibsrv.net/gimg/rennlis...452bfbf04.jpeg |
I probably will upgrade to the LCA monoballs in the next round of upgrades. To start I was doing these ER monoballs, adj rear sway and drop links, solid LCA thrust bushings and some toe control arms.
Originally Posted by 03EvoIII
(Post 15559984)
Originally Posted by Oak
(Post 15560004)
it’s imperative to go with proven components don’t get bamboozled by all the bling. A lot of Chinese made components made from sub par materials. It will transform your turbo to a lethal track weapon. Even by modern standards. |
(Post 15560044)
What 'bling' are you referring to regarding my post? Are you saying that Elephant Racing parts are made in China? As far as I know they are quality components made in the USA. Thanks for the help :rolleyes:
Elephant is quality
Quality? A buddy of mine had Elephant upgrade his 997 suspension and it is terrible. He even failed a track inspection because they installed it wrong. He finally sent it to another shop in Los Gatos and had them correct everything. The tires no longer rub but his car still sounds like it's going to break with everyone bump.
Originally Posted by PaleAle
(Post 15561082)
the bottom line is: monoballs on a primarily street driven car are "overkill". the more 'rubber" you eliminate, the more.... never mind.
Maybe he's in the process of building a race car.
Originally Posted by Carlo_Carrera
(Post 15561084)
How is that the fault of the parts manufacturer?
(Post 15562172)
Maybe I wasn't clear. He bought the parts from Elephant AND had them install it. I'm literally sitting here, wearing the T-Shirt the owner gave me when we picked up his car. We're not talking about about $300 expense here...
(Post 15562432)
I get it, but I am pretty sure Elephant farms out their manufacturing to someone else so I am not sure we can judge the hardware quality properly if some dope employee installed it wrong. What do you think? Is the hardware itself f'd up?
now.. the thread is diverging into the "reason i swapped out my tarrett's that didn't seat properly and i went back to oem's" territory.
monoball's are NOT for STREET use in lieu of oem top mounts lol. |
