New Used Cluster
Gents, I just installed a used cluster in my 996 Turbo today. It is the correct part number and everything works perfect. However the mileage reads only 23 miles! I wish that was the case. The real mileage on the car is 31,185 miles. Any ideas fellas? Cheers, Mat |
Check out these links:
https://rennlist.com/forums/996-turb...-be-a-way.html https://rennlist.com/forums/996-foru...age-reset.html From the second thread: What I said is not quite correct. An instrument cluster with less than 62 miles on it can be changed with the PST2. It can only be changed to increase the miles - as would be done on a new cluster - to match the miles on the car. No code is needed from PCNA. With the PST2 hooked up you input the car's VIN and the milage you want the cluster to show. Peter was going to do this for me when I bought the "new" 996 cluster off ebay. Since the used 996 cluster had 990 miles on it Peter could not change it. Once the cluster has recorded more than 62 miles it is locked and cannot be changed with the PST2. But, private companies can make the cluster show any milage you want. |
Thank you for the reply.
However mine is clearly a used cluster and no telling how many miles it has on it. However, once installed in my car with 31,185 actual miles it only shows 23 miles. To clarify, so I need to address the mileage correction before I hit 62 miles on this "new/used" cluster with a PST2? Thanks, Mat |
That is my understanding from reading the above threads, but I have not done it myself.
Here's the full thread that was the source of that info: http://babblers.org/showthread.php?t=4364 Loren mentions Palo Alto Speedometer if your mileage is over, in another thread: http://babblers.org/showpost.php?p=47376&postcount=5 Good luck! |
If I remember correctly Powerhound knows a guy that can program your odometer to the correct mileage.
Paging Powerhound. |
Originally Posted by Carlo_Carrera
(Post 15557463)
Paging Powerhound. Powerhound can you help? Thank you gents! |
needs to be programmed with PIWIS
PIWIS? |
Originally Posted by SeabrookPorsche
(Post 15557472)
Carlo! Always the man!
Powderhound's guy is excellent, and very protective of his legitimacy. You will need to prove the miles you want the cluster set to -- he may require you to send the previous cluster.
I had the cluster adjusted to the correct mileage today using the PST2. He did it in about 5 minutes. Done deal.
However, after looking a bit closer the Oil Gauge is not working. Can anyone recommend someone to have this repaired? Thanks again gents. |
I hate to say this but my experience with the oil gauge in the cluster not functioning means you need a new gauge cluster. I hope I am wrong.
However, after looking a bit closer the Oil Gauge is not working. Can anyone recommend someone to have this repaired? Thanks again gents. You'll need to send out your whole cluster it's easy to remove for a new computer to fix that issue it's about $750 give North Hollywood speedo a call. |
(Post 15561064)
