Front shock top mounts
Hello fellow 996tters my 03 tt is making the squeaking sound when turning. My local Indy replace the front thrust arms only a week later the squeaking sound return. Now they told me to replace the top mounts. The dilemma is should I just stick to the stock Porsche units or should I upgrade to the Tarrets units. My car is 99% street use but I do exercise her regularly. I’m getting old now, so squeaking car drives me but. Thank you for your guidance |
stick with the oem mounts.
Sounds like stock mounts would be the way to go in your case as the monoball ones will make a good bit more noise.
look into the elephant conversion units. you cut out the rubber from the oem mounts and a monoball is installed and screwed into place. about 300$ for the set for the front
If you want a cheap OEM solution, get the OEM 997 turbo front strut mounts. They are a direct replacement for the 996 ones and 90 per side on suncoast.
Originally Posted by solow
(Post 15555205)
997-343-015-02 and 997-343-016-02. Order the bearing plates as well, you will likely need them. 996-343-501-00 |
Why do they even bother making the 996 mounts if the 997 mounts are half the cost?
They probably don't make them anymore but Porsche still has plenty in inventory?
I'll buy that.
Originally Posted by 32krazy!
(Post 15553719)
Scot |
Originally Posted by pfbz
(Post 15555272)
^^^ this is what I did on my recent suspension install.
Originally Posted by 03EvoIII
(Post 15557791)
I just received mine ER strut monoballs for front and rear among with some other upgrades. Looking forward to seeing how it feels!
Scot Brett |
