Winter wheels, will they fit? - Rennlist - Porsche Discussion Forums
Old 01-07-2019, 08:50 AM
B1ackmarket
New User
Default Winter wheels, will they fit?
Hey guys, new to the 996TT scene. I was able to get a nice set of 19 inch winter setup off a carrera 4s 997.2. My question is, will I have any issues fitting them on my 996.
Thanks - B
Porsche 997 19-inch Winter wheels set, Carrera S II, rims 8J x 19 ET57 + 11J x 19 ET 51, Winter tyres 235/35 R19 + 295/30 R19
B1ackmarket is offline
Old 01-07-2019, 11:01 AM
Carlo_Carrera
2011 Rennlist F1 Champion
Carlo_Carrera's Avatar
Those tire diameters are not compatible with the AWD and PSM system. You need the tire diameters front to rear to be as close as possible.
Carlo_Carrera is offline
Old 01-07-2019, 12:45 PM
B1ackmarket
New User
thanks, is that just a 996 situation? The wheels came off an Awd 997.
Old 01-07-2019, 02:24 PM
jblaw
These are within 2% -- I thought anything less than 4% was ok?
jblaw is offline
Old 01-07-2019, 03:27 PM
Carlo_Carrera
The AWD/PSM drive system in the 996 is completely different than the system on the 997.2.
The 996TT system needs the diameters to be nearly the same. On my car I ran 245/35-19 and 285/30-19.
Old 01-07-2019, 03:29 PM
Carlo_Carrera
4% is way too different. I consider anything more than 1.5% to be detrimental to your viscous coupling and the PSM system will not like it either. The OEM tire size diameters are nearly identical front/rear for a reason.
Old Yesterday, 05:52 PM
B1ackmarket
New User
do you guys think these will work for a 996tt? Coming off of a 2006 c4s
Front 18X8.5
Rear 18X10
Tires:
Michelin Pilot Alpin N2 (Porsche) Never repaired
Front - 235/40 R18 Tread 9/32 nds
Rear - 265/40 R18 Tread 6/32 nds
Old Yesterday, 09:28 PM
Carlo_Carrera
Absolutely no, those tire sizes are way out of spec for an AWD 996TT.
With a 996TT you want the front and rear tire diameters to be almost exactly the same. Those tires sizes front/rear are almost an inch different in diameter.
Need to know the offset of the wheels to judge them. They will probably fit fine.
Old Today, 01:02 AM
Carlo_Carrera
Winter tire sizes that work with 996TT AWD are:
225/40R18 265/35R18 (requires 10" rear wheel width)
215/45R18 275/35R18 (works with stock TT wheels) (my personal favorite combo)
235/45R18 275/35R18 (works with stock TT wheels)
Contact Us About Us Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
