What is this gasket?
I found this sitting on the floor board just under the pedals this morning. Looked up the parts diagrams and can’t located what it is for, figured maybe something to do with the AC/heater vents? It’s a red hard foam gasket type thing. Unfamiliar with its shape as to what it could go to. Thoughts or concerns? https://cimg4.ibsrv.net/gimg/rennlis...fcad11089.jpeg https://cimg5.ibsrv.net/gimg/rennlis...e133a848b.jpeg https://cimg6.ibsrv.net/gimg/rennlis...feb33636d.jpeg |
AC ducting.
Thanks for confirming my thoughts. Clearly not a singular part that can be purchased and replaced. Can’t seem to find anything remotely looking like a gasket for the AC parts in the diagrams
Originally Posted by pfbz
(Post 15544046)
AC ducting.
Originally Posted by 06Turbo
(Post 15544055)
Thanks for confirming my thoughts. Clearly not a singular part that can be purchased and replaced. Can’t seem to find anything remotely looking like a gasket for the AC parts in the diagrams There is one duct that goes right across underneath the drivers footbox from the center section to the side. It is also perhaps the most frequently removed duct to get access to the stuff under the dash, pedal switches, throttle encoder, etc. so my guess is that it is from that particular duct that the foam came from. |
I’m not going to worry about it unless without the gasket it creates a rattle sound that overpowers the current loose screw/washer rattle I have under the dash somewhere. If anything it probably will allow more warm/cold air on my toes. |
