Clutch replacement price check - Page 2 - Rennlist - Porsche Discussion Forums
Old 01-02-2019, 09:13 PM
Carlo_Carrera
2011 Rennlist F1 Champion
Carlo_Carrera's Avatar
Originally Posted by "02996ttx50 View Post
forgive me, but a DMFW alone is $800.00 Minimum...
A DMFW at rockauto.com is half that.
They have entire clutch kits including a DMFW for $800
Carlo_Carrera is offline
Old 01-02-2019, 09:28 PM
pfbz
pfbz's Avatar
I just did a clutch as well, ~62K miles on original clutch. I went with stock dual mass flywheel, GT2 clutch disk, Sachs 764 pressure plate.
The biggest "while your in there" job for me was opting to do a full factory style GT2 clutch slave hydraulics conversion...
For me, that was a OEM GT2 clutch slave, oem gt2 clutch fork, oem gt2 clutch hose, oem gt2 clutch pedal spring.
Labor for installing all of the above included drill and trap the transmission itself (for the opposite-side GT2 slave instead of flexy aftermarket bracket), reworking the power steering pump to remove the coupler that provided the clutch hydraulic pressure, flushing the master and any other reused parts from any residual pentosin, installing GT2 clutch pedal assist spring, etc.
My shop was at 8 hours labor for clutch plus 6 hours for the clutch hydraulic conversion.
While labor for the factory style GT2 clutch conversion is definitely more hours than installing some of the conversion kits out there, doing the factory style conversion with oem parts actually has a significantly lower parts cost to balance it out a bit.
pfbz is offline
Old 01-02-2019, 09:51 PM
"02996ttx50
Super User
really? the "LUK" was 800 last i checked. any provenance on the $400 DM flywheel? thats awful cheap.
i sit corrected. looks like i'll get my next one there. LUK DMF153 Dual Mass Flywheel Info
Turbo$442.99Add to CartBRUTE POWER/PERFECTION CLUTCH 502790 {#99611401250} Dual Mass Flywheel Info
For OE Dual Mass Flywheel System (Only 2 Remaining)$596.79
"02996ttx50 is online now
Old 01-02-2019, 09:52 PM
mffarrell
User
mffarrell's Avatar
Can you feel the difference with the GT2 clutch disk?
mffarrell is offline
Old 01-02-2019, 10:06 PM
"02996ttx50
Super User
no difference in feel or clutch action when using the unsprung gt2 "rigid" disc....
so back off topic...after looking, that rock place is dirt cheap, i'll concede that. but even their OEM sachs clutch kit sans flywheel is over $800.00
apples to apples. i'm unfamiliar with those aftermarket names that sell "kits" for "half that" who knows. i'll stay with oem sachs stuff for my clutch as the clutch is a lousy place to "test parts" imo.
Old 01-02-2019, 10:12 PM
pfbz
pfbz's Avatar
Oh yes.... A proper clutch! Firm but not silly firm pedal, crisp engagement, great clutch feel. Took about two minutes to adjust to the new clutch feel and am super happy with it.
996/997 Turbos are amazing cars, but Porsche IMHO had a huge swing-and-a-miss on these cars with the hydraulic assisted clutch system and hydraulic spoiler rams!
[whoops, I see you were asking about the clutch disc, not the clutch hydraulics... Above comments are for the entire system, not sure I can pick out the difference in the clutch disc only]
pfbz is offline
Old 01-02-2019, 11:17 PM
"02996ttx50
Super User
ordinarily, i would agree on the hydraulically assisted clutch being problematic, often providing inconsistent feel. but i have found over these many years that once you eliminate the requirement of engaging the clutch "pre-igintion" by disabling the "switch", you will eliminate the undue stress to the accumulator which is the *usual* source of failure on the car which leads to fluid migration to the master, and accompanying slave issues etc.
switch eliminated? my clutch is "proper".
only thing i can say about the wing, is keep it clean and re-bleed as required. there is a reason porsche has factory "re-bleed' instructions for the spoiler. still works for me.
Old 01-02-2019, 11:55 PM
88mmm
User
The aftermarket kits are just sachs parts. I bought the Luk gt2 kit and it was all sachs parts. They are apples to apples just don't carry the sachs packaging.
https://rennlist.com/forums/996-turbo-forum-61/
88mmm is offline
Old 01-03-2019, 01:03 AM
"02996ttx50
Super User
i don't know that, but you do(?). i do know the LUK is an OEM supplier and that is good enough for me.
the other bits? again, i would experiment with parts like i.e. brake pads and many other maintenance items, but unless i was certain beyond any reasonable doubt. i wouldn't put aftermarket generic clutch parts in unless i was building out the usual hi perf upgrades. sachs is sachs, though.
good for you, for finding them so inexpensively. hopefully they end up being "oem" equivalent. i last changed my clutch at 100k miles. i hope to need another replacement, ten years from now.
Old 01-03-2019, 01:39 AM
pfbz
pfbz's Avatar
I agree that deactivating the "clutch in to start" switch and starting in neutral really helps... It helped me live with my clutch for an extra year.
But even with the improvement in consistency, it's like night and day moving to the GT2 clutch, from livable to awesome. I'm sure opinions differ, and I wouldn't be quick to do the swap unless the transmission was already down for a clutch replacement or if your slave has failed, but the difference is quite noticeable and changes the feel dramatically for the better, IMHO of course!
pfbz is offline
Old 01-03-2019, 02:54 AM
"02996ttx50
Super User
i have no doubt the proper gt2 conversion, is optimal and know also the rube goldberg hydraulics weren't configured for either of us. the original target buyers or their husbands, perhaps?
i just haven't had to "spend" to make my clutch as "good" as oem/stock can be. the only issues that contribute to clutch inconsistencies, are those that have to do with the "clutch in" requirement as you say. this is factual. that said, i also agree the *feel* of a "non assisted" clutch is "best".
Old 01-03-2019, 10:59 AM
docwyte
docwyte's Avatar
What's this about deactivating the "clutch in to start"? How do I do that?
docwyte is offline
Old 01-03-2019, 01:39 PM
Viperbob1
Viperbob1's Avatar
We charge 8 hours for the clutch job on a 996TT. Also good time to check rear main seal. If we convert to GT2 hydraulics (which are GREAT in these cars) it is 4 hours for the Evoms unit and 2 hours for the BBi unit. The BBi is simpler to install, but more $$ upfront. Both work fine.
Viperbob1 is offline
Old 01-03-2019, 01:58 PM
Road King
User
Road King's Avatar
my factory clutch also died at 40K miles. Fortunately for me, I bought the car with 44K miles so the previous owner paid big bucks for a factory clutch from a local San Diego Porsche dealer. If I was changing the clutch on my time / my dime, I'd address those coolant lines at the same time!
Road King is offline
Old 01-03-2019, 02:16 PM
"02996ttx50
Super User
there is a switch at the pedals ( the clutch ) that once disconnected will eliminate the requirement of engaging the clutch to start the car. once you do this, you won't need to replace the accumulator or have engagement issues. again, as long as all you internal clutch components are within "spec" and not unduly "worn". inconsistent clutch feel has to do with the hydraulics and not the clutch itself.
im sure there are many DIY threads on this. ( i spent 20 mins trying to find just one. to no avail.. sorry )
Contact Us About Us Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
