Car won't start after gas fillup
Hi Everyone
This is my first post for my 2003 Turbo, 6 speed. Had the car about 6 months, got it from the local Porsche dealer with 35k miles, excellent condition.
The last two times I filled up with gas, the car would not start. The first time it happened there was also a check engine light (code P0446) just prior to the fill up. I had AAA come out and the tech tried locking and unlocking the car twice, and it started. Took it to a local mechanic and they diagnosed the problem as a stuck purge valve for the evaporative emissions setup. Car ran good and started okay until today, when I filled it up again and experienced the same problem, no start. Waited about 15 minutes and finally got it started after 3 cranks. Battery is strong.
Any thoughts would be appreciated!
Welcome..
I'd check your in tank fuel pump for the "split hose" failure. You will hear the fuel pump, but the hose is split, thus not allowing fuel to get to the fuel rails/injectors.
Rob
This happens with the first gen Cayennes routinely - it has happened to both of mine, exact same symptoms. And it is a bad purge valve. What happens is that the purge valve allows the gas vapors when filling the tank to flood the car. It will start OK after you wait about 5 minutes or so. A way to work around the problem is to not fill up more than half a tank at a time. So, I suppose you could test the theory by limiting yourself to getting only about 5 gallons of gas at a time - if your car starts, then that would further indicate a bad purge valve. Also, if you get a full tank of gas, then let the car sit for about 10 minutes and if it starts fine, another confirmation.
Here's a link to a thread in the regular (non-turbo) 996 forum that is on point:
https://rennlist.com/forums/996-foru...stem-woes.html
I'll bet the system is the same or very similar to the 996tt fuel system.
I want to thank all of the people on this forum who have responded, there is truly a wealth of knowledge here, I am very impressed!
Rob
is the problem solved. if not i’d suspect the the TPS ( throttle position sensor) is going bad. same scenario on wifes Benz and a my indy mechanic diagnosed it immediately.
