ABS Module
Yes, ABS/PSM. It looks as though you can use the hydraulic pump side of a used unit as a doner to attach to the existing ecu side. In fact, success stories have shown that it can be done with a non-Turbo module as long as the doner unit has PSM.
I suffered through that error code for 18 months. I changed a speed sensor, brake sensor and was ready to go for a new module. Then I took the advice of guys on the board and changed the wiring harness for $82. Bingo....goodbye ABS/PSM.
I almost didn’t try changing the wiring harness because my car has not been lowered. Logically it just didn’t make sense. Sure glad I did. FYI, I’m not a mechanic and I did it myself in 2 hours.
