Is this a decent deal?
Been watching these cars for a while now and watching prices creeeeeppppppp up on BaT. I've been looking for a daily driver and I'm finally close to pulling the trigger on an '02 6MT 75k miles for a bit $40k. Seems fairly well-sorted: 2-owner car, brand new tires, water pump, but not sure if any of the other major items (clutch, coolant pipes) have been addressed. Needs a CV boot, and o-ring seal on one of the turbos and the rear spoiler hydraulics are shot. PPI by a Porsche dealer being performed tomorrow. The car was already inspected by an independent shop for someone else, and I spoke with the inspector whom divulged the few issues above, and said it drove well (said they got on it fairly hard), and there were no perceived clutch issues other issues, leaks, etc.
All in all, I'm not looking for a garage queen, just something that I can put on a few thousand miles per year, and not worry about losing value. Looking to be under $40k, and still have room to enjoy for a few years and be able to sell without losing value.
Thoughts?
Thanks in advance.
Thoughts?
Thanks in advance.
...an '02 6MT 75k miles for a bit $40k. Seems fairly well-sorted: 2-owner car, brand new tires, water pump, but not sure if any of the other major items (clutch, coolant pipes) have been addressed. Needs a CV boot, and o-ring seal on one of the turbos and the rear spoiler hydraulics are shot. PPI by a Porsche dealer being performed tomorrow. The car was already inspected by an independent shop for someone else, and I spoke with the inspector whom divulged the few issues above, and said it drove well (said they got on it fairly hard), and there were no perceived clutch issues other issues, leaks, etc.
Do you know if it has been tracked? Is it tuned? Does it have stock suspension and/or exhaust?
I'll have more info tomorrow from the PPI; so I'll report back then with further details. I wish I could find a way to track down the prior owner....thoughts?
A Porsche dealership is probably the worst place to have the car inspected as they use a very rote checklist. a good indie would be a much better and even more comprehensive ppi.. hopefully the first inspection provided enough info for you to make a decision. you'll be disappointed with a PPI from a dealer. its basically a CPO "list" and would miss a LOT of issues if they were "hidden".
40k sounds good as the items it needs are minimal and by no means deal breakers. i've had two of these and my current one was purchased with similar mileage. i've MORE than doubled it since with zero major issues.. GL.
$40K is about the minimum one can expect to find a semi-decent 996 turbo 6-speed coupe for (under 75K miles, no salvage, no big carfax issues, no known leaks, doesn't have any immediate big ticket repairs needed, etc)...
But even with the most thorough PPI, plan on finding a few things that will need addressing to get it fully sorted.
My #1 criteria is cosmetic condition, inside and out. If it looks beat, scraped, worn, that's just not easy to fix.. After that, well sorted mechanically with *recent* work.
