996 Turbo Forum 1999-2005
help identifying clear slippery fluid leak (center of car)
Old 12-03-2018, 01:27 PM
HTX996t
HTX996t's Avatar
Default help identifying clear slippery fluid leak (center of car)
I was installing a new eRam kit in my car this weekend (much love for seized bolts on the engine lid liner!). After I moved the car for a test drive I noticed a clear, slippery fluid on my garage floor right in the center of the car, slightly ahead of the midpoint (front to rear). The fluid is completely clear, odorless, and yes, tasteless. Any idea what it could be? I attached a photo below and the blue outline circles some wetness around the underbody shield. Thanks!
Old 12-03-2018, 01:30 PM
RngTrtl
RngTrtl's Avatar
Pentosin?
Old 12-03-2018, 01:37 PM
T Kono
T Kono's Avatar
Swab onto a white suface........green tint = Pentosin, clear / yellow = brake fluid? Truly colorless & odorless......were you running the air or defroster (evap runoff)? Interesting, I have never seen bolts & fender washers substituted for the spring clips used on the front shield.
Old 12-03-2018, 01:38 PM
HTX996t
HTX996t's Avatar
Originally Posted by RngTrtl
Pentosin?
I don’t think it has anything to do with the hydraulic rams, merely giving some background.
If that is Pentosin, do you have any idea where that pentosin would be leaking from at that spot?
Old 12-03-2018, 01:42 PM
HTX996t
HTX996t's Avatar
I’ll try and swab some to see if there’s any tint, but I don’t believe there is. It did not evaporate and the residue remains slippery on my garage floor even after wiping up (epoxy flooring). Definitely ran the AC, but I assume that would just be water?
Any chance it it could be the center differential, viscous coupling, drive shaft, etc leaking fluid?
Old 12-03-2018, 01:44 PM
T Kono
T Kono's Avatar
Possible I suppose, how many miles? When I changed my diff oil at 50,000 it definitely had color. Evap runoff would be water, yes....not oily.
Old 12-03-2018, 01:48 PM
HTX996t
HTX996t's Avatar
104k miles.
Old 12-03-2018, 02:15 PM
T Kono
T Kono's Avatar
I would pull the shield and have a good look around with a strong flashlight. Hopefully you spot the issue if any.
Old 12-03-2018, 02:20 PM
Third-Reef
Third-Reef's Avatar
Viscous coupling fluid should be a black goo, not likely that it is it. AC condensate usually comes out of the front of the car, just behind the steering rack,
My guess is trany oil, but i don't know what it tastes like so you are on your own there.
Forgot about coolant, what color is yours? It tastes very sweet.
Old 12-03-2018, 05:06 PM
32krazy!
32krazy!'s Avatar
shields need to be pulled and look for the source. could be way away from were it drips due to the shields
Old 12-03-2018, 05:27 PM
HTX996t
HTX996t's Avatar
I appreciate everyone’s help. I pulled the shield and it looks like the passenger side axel shaft backed out. I had new ones installed as part of my front end/suspension rebuild. Will be taking it back to the shop to see what happened and get it remedied. Anyone here have any ideas what would cause this in the first place?
Old 12-03-2018, 10:23 PM
RennKit-Dave
Basic Sponsor
RennKit-Dave's Avatar
Thanks for the eRam mention! Glad you found the problem - did it back out of the dif or the hub?
Dave
Rennkit
djcooper@rennkit.com
http://rennkit.com/
  • Patented eRam Kit™ for 996/997 Turbo & Carrera GT wings
  • Cal*Cool™ - brake cooling 996/997 / Bluetooth Retrofit Kit™ for 1998-2011 cars / Wing Extenders™ 987 Cayman / 997 Turbo
  • AUTO-BLiP for MT / Function F1RST Shift ***** / Girodisc 2-piece rotors / OS Giken LSD / Phenix suspension / Zunsport grills / 997/987 switches/PCM ***** / Border Coilovers
Old 12-03-2018, 10:32 PM
HTX996t
HTX996t's Avatar
I think it backed out of the diff, but I’m no expert. Here’s a pic of the axle.
Dave-eRams were great, instructions are thorough and if it weren’t for the previous owner, would have been dead simple. Had seized bolts for the lid liner and what looks to be a radar detector wired and screwed into the lid liner that messed up wire routing-but we got it worked out and I couldn’t be happier to see that spoiler pop on the freeway!
Old 12-05-2018, 11:43 AM
FRUNKenstein
FRUNKenstein's Avatar
+996 on the Rennkit eRam. It so nice to know that I'll NEVER have to worry about that stupid hydraulic system again!!
Old 12-06-2018, 11:32 AM
RngTrtl
RngTrtl's Avatar
Pentosin is used for the power steering pump and thus the power assisted clutch mechanism, i.e. slave cylinder that resides on top of the transmission.
Quick Reply: help identifying clear slippery fluid leak (center of car)
