996 Turbo Forum 1999-2005
Joined the club
Old 11-26-2018, 03:56 PM
Atrox
Atrox's Avatar
Not the one under the oil cooler that one is well hidden.
Old 11-26-2018, 05:01 PM
Atrox
Atrox's Avatar
5k to pull engine and prep parts for welding. Does not include welding for that 5k. Does that sound reasonable?
Old 11-26-2018, 05:54 PM
my04996tt
my04996tt's Avatar
If you google this you will find several write-ups on how to pin all 8 fittings. There is a good one from 6speedonline forum dated 8/20/2015.
Old 11-26-2018, 07:53 PM
Carlo_Carrera
Carlo_Carrera's Avatar
Received 2,218 Likes on 1,429 Posts
Sounds high. $5k should be the total price, welding included. Offer to pay cash.
I believe you do not track this car? If that is correct, and I were you I would re-glue the pipe and drive on.
Old 11-26-2018, 08:19 PM
Atrox
Atrox's Avatar
Never tracked it, nor plan too. Simply a weekend car with tune and 41,000 miles.
Old 11-26-2018, 10:04 PM
nerdtalker
nerdtalker's Avatar
I had the same thing happen to my 996TT Cab. I wasn't planning on getting married to a car that's not going to the track anytime soon, so I just JB welded it back in. It was very visible and easy, the one behind the alternator. My indie advised me this likely will only last a year in his experience before blowing again, but I'm willing to gamble since I have two 996TTs and AAA premiere.
My protips on the matter are completely remove the failed pipe, wire-brush it spotless, thoroughly clean it and the corresponding mating surface with IPA, roughen up the surface a little bit so the epoxy can weld, then apply JB weld liberally to both surfaces, lock it in, wait a long-*** time for it to cure fully (I waited over 48 hours), then pressure test with a vacuum lift to refill the coolant system.
Old 11-27-2018, 03:53 PM
rael
rael's Avatar
$2500 all in for pinning here in Phoenix at my indie.
Old 11-27-2018, 08:53 PM
manimal
manimal's Avatar
Did they drop the engine? That sounds like a good deal.
Old 11-27-2018, 10:36 PM
FRUNKenstein
FRUNKenstein's Avatar
Just talking off the top of my head, but $5k+ seems high. I thought this was closer to a $3,000 fix.
Old 11-28-2018, 02:53 PM
Turbodan
Turbodan's Avatar
I had 993GT drop my engine and tranny, replace the clutch and pin the lines. I think it took him about 23 hours all in. So yeah 5k US seems excessive. I have heard of shops charging 8k for this. They are praying on people's fears and overcharging IMO.
If anybody is near Toronto and needs this done, I would talk to Rob as his attention to detail is excellent and he is very reasonable and experienced with these engines.
Old 11-28-2018, 04:30 PM
rael
rael's Avatar
Yes, full engine drop. They've done over 20. McIlvain Motors in Tempe, AZ, pretty much late model Porsche only shop, though I occasionally see and Audi or Benz, but not often. They do all the heavy lifting on my GT3 and 996TT, although ironically I have not had the Turbo lines pinned yet, as the car has only 19k miles on it and the engine has never been out.
Great guys and a full-transparency shop.
Old 11-30-2018, 06:11 PM
Atrox
Atrox's Avatar
So they got car put back together and now car has coolant coming out of exhaust. They seem to think it may be a head gasket failure. I won’t know anymore until shop owner takes a look at on Monday. Not the news I was looking to get. Sounds like I have an exspensive problem.
Old 11-30-2018, 06:16 PM
mffarrell
mffarrell's Avatar
was the engine overheated, once you noticed the blown coolant line?
Old 11-30-2018, 06:20 PM
Atrox
Atrox's Avatar
Yes, I was in the middle of passing a semi on two lane highway so I drove maybe 1/4 mile until I could safely pass and find a secure spot to stop.
Old 11-30-2018, 07:15 PM
mffarrell
mffarrell's Avatar
I guess if it got hot enough, it could of crack the heads, but only going 1/4 mile, it’s hard to say. Good luck, sorry this happened to you.
Quick Reply: Joined the club
