Troubleshooting Clutch Hydraulic System
I checked my clutch reservoir and it was almost empty. Up to then, clutch pedal felt normal. I filled it to the max. line, and pumped it 125 times, then looked for a leak which I could not find. So where did the fluid go? Is it possible that fluid went back into the PS reservoir? I have heard of the PS fluid going the other direction and overfilling the clutch reservoir, but not draining the clutch reservoir
One thing that I must mention is that I changed my PS reservoir last year, but did not check the clutch reservoir after completing the job, as I assumed the slave cylinder was isolated from the clutch master cylinder and reservoir.
Thoughts?
Thoughts?
if the reservoir in the front was empty you need to bleed at the slave to get the air out. if you filled it and fluid went down, it could be anywhere (in the ps reservoir, in the accumulator (most likely) or dripping down the reservoir in the front, or down side of transmission. the reservoir in the front doesn't hold much so it probably went to your accumulator. Sounds like time to get a new slave...have fun doing the bear hug sunset has 20%off for black friday
Do you think it’s possible I lost fluid in the clutch reservoir when I changed the PS reservoir? I have a slave and accumulator loaded in the cart since yesterday, just in case. Luckily I have a two post lift in my shop just in case I need to replace the slave and accumulator.
check the fluid in the ps reservoir, but most likely you need a slave. if you don't need one now most likely you will in the next couple years anyway. you could try bleeding the slave and see if that works. I assume their is no pentosin on the floor or under the reservoir?
No, the clutch master cylinder is dry both inside the car and in the frunck...no signs of leaks. The clutch pedal is fine, no need to bleed.
Sunset has a 20% off sale this weekend and I am almost tempted to purchase a new slave and accumulator just in case, or if/when it fails.
Do you think that most of the fluid in the clutch reservoir was lost during the ps reservoir replacement because I thought the two systems are isolated by a check valve in the slave? I know the clutch reservoir was full before I changed the ps reservoir, but I didn't see the need to check after the ps reservoir install. A year later is when I discovered most of the fluid was gone.
i wouldn't think so? i replaced my ps res also but its been so long ago i cant recall any details. once in a rare while i need to add some ch11s. but if theres no migration to the slave reservoir under the bonnet AND its dry? again, i'd just keep an eye on it. GL w it, i'm sure its fine.
Had a similar problem and after replacing slave & accumulator turned out to be a pressure leak at the compression fitting of the flex line at the slave. Dealer didn't find, shop didn't find as left no trace.
