Sluggish/Repeated Start, High Idle RPM
Hi All,
Car is 2002 996 Turbo and 100K miles.
Recently it's difficult to crank-start the car. It would take more than 10 seconds or repeated-tries to start the engine. Once the engine is started, its idle RPM is a bit higher than normal, which is like 1K rpm and above; normal is 800 RPM. Car drives normal afterwards, except higher than usual RPM constantly and no warning lights.
This happens randomly and intermittently, either engine hot or cold.
After driving a few hundred feet or a few minutes, if I try to stop-and-restart the engine, it becomes normal; no start difficulty and normal idle RPM.
Any ideas please?
Thanks!
Any ideas please?
Thanks!
Yes, look at the MAF. For a quick check just unplug it and start the car. Also check/listen for a vacuum leak.
