C2 uprights conversion discussion
Thinking of getting C2 uprights when I go 2wd to improve steering feel.
Does anyone know the difference in diameter between C2 and turbo struts?
I'm thinking of keeping my tt PSS9's and boring out the C2 uprights to fit (as long as the difference isn't too great.) Also, of the C2 upright variations (986, 996, 997, 987, etc), which is the beefiest for this project?
I did this a few years ago when converting my Ducati from Showa to Ohlins forks- they use the same bottom yoke with different bores, and Ohlins yokes are rare and expensive. Was wondering if the same idea couldn't be applied here.
GT strut diameter is narrower than the TT struts, you will need a bushing/liner to fit correctly.
I think keeping the TT carriers would be a better a choice than going to C2. if you plan on switching I would go with GT uprights.
don't see any real issue using C2 uprights, but you may need to go aftermarket on brakes to get big enough
TT struts are too big O.D. to fit into GT2/3 uprights
IIRC, 997's have the same bolt spacing as 996tt, correct?
Also, wrt: strut diameter, I was thinking of boring the upright to fit the tt strut if it’s not too big of a difference.
If it's too much trouble, maybe it's time to sell those, and upgrade to Ohlins...
C2 upright is basically identical to the GT3 upright but uses a much smaller bearing than a GT2/3/Cup upright or the TT upright, both of which share the larger bearing. The C2 bearing uses the small Boxster bearing which will fail under hard track. I would not do it.
John, is there more material on the GT3 upright or are the casting practically identical other than the bore? Or could the C2 upright be bored out to fit the larger bearing?
