350mm brakes
350mm brakes
Hello,
I have a 02 996t w/6 piston porsche GT2/3 calipers w/Pagid Yellow pads..
Im looking to replace the pads and rotors for a more street setup...
Can anyone recommend which pads would fit this caliper with most initial bite?
Would I need 350mm 997tt rotors, or 996 Gt2?
Hello,
I've used Sebro slotted in the past on the track with good results, they'll be fine on the street and are also cheaper.
if you're running stock 996tt front uprights then you need 997tt discs... 997tt will fit all-round
if you're 2wd with GT2/3 uprights you will need 996/7GT3 front disc sizing
oem pads will probably be your best bet for street only
For the aggressive street it's my recommendation to BUY Genuine Porsche Sport pads up front. You can cheap out and purchase the Textar pads for the rear. The pad formulation is different with the Genuine Porsche pad. No noise, moderate duct and good performance from cold.
You can also install the SEBRO slotted 350mm rotors at all four corners. Bolt on for the 996TT/997TT.
