New ignition switch faulty?
#31
Where is it located in the car?
#36
Under the dash, passenger side foot well, right on the other side of what the positive lead from the battery anchors to. It's in the current distributor, basically a fuse block with 7 fuses. This one is #4, which protects the ignition lock, and mine has no continuity through it.
https://workshop-manuals.com/porsche...tion_sheet_20/
This would explain why I have no 12v in my ignition switch harness.
#39
Good job.
This is first time I have heard that fuse blowing. I hate to say it but the blow fuse is just the symptom. There is a reason it blew.
#40
However, I am also open to the possibility that I may have some other issue. Time will tell.
I plan to disassemble the faulty part and see what there is to see inside.
I am excited to see if this simple fix remedies my issue.
#41
At 17 years old (as evident by the color coded tape on the sealed box that this came out of) I would begin to explore the possibility that it could 'wear out'.
#42
