Oil leak?
Laying a surface bead will work.just as someone said use a bias wrench when breaking the drain plug loose and tightening. The weld is not under any real stress, so i bet a bead will work.
This is a fracture or split. I have replaced a oil tank with a very similar issue. 32Crazy is correct, you will need to remove from the engine and clean before welding or brazing. You don't want the oil to carbonize and get pushed into the engine.
Inert gas should be used to purge the tank. The fracture that I seen was in the corrugation. I just opted to replace the tank vs risk heat induced stress fractures.
I happen to have a used 996 Turbo oil tank if you decide to replace it. Was mislabeled as a 997 Turbo tank on eBay and by the time I got around to the job and noticed it was way too late to send it back.
Hmmm...now that you mention it. I did took the car to the dealer for an oil change prior to the excessive leak. I knew it was leaking but never this bad. It got worse after the oil change. The car sat for a week after the oil change and that's when I notice the oil on the garage floor. Prior to that the car never left a stain on the floor. I don't think I'll go back. I usually do my own oil change. But I was hoping the dealer can catch something with Porsche world class routine visual check up. They didn't even catch oil around the tank (smh). I figured if they didn't mention it, it's normal.
Thanks. I will let you know. I want to sort out what else I need to work on when the engine is out.
Originally Posted by bansasn
Anyone have any ideas how much to replace an oil tank at an Indy shop? Thank you.
Thanks. Now is the time to order my Kline system and change the spark plugs. What other critical item do I need to address when the engine is out? I want to do everything all at once when the engine is out for the first time. Don't want to have any trouble down the line.
Weld/pin coolant tubes?
Expansion tank
Water pump
Check valves (I thought there was only one, but there are two)
Oil pressure sending unit
Metal turbo oil feed lines checked
Waste gate vacuum lines
5 bar fuel pressure regulator
Clutch kit w/LWFW
Slave cylinder (found it was leaking a bit with the engine removal. Bad news/good news)
Pressure accumulator
Spark plugs
Water hoses
Fuel filter
Air filter
Crankshaft seal
Boost pressure test
Wastegate adjust
Throttle body seal
Coil packs
Solenoid brackets
Engine mounts (RSS)
Trans mount (997 version)
Multi-rib belt
2nd gear detent if needed
999 707 410 40 o-ring coolant temperature sensor housing+ 3 other coolant pipe housing 4 $2.75 ($11.00)
999 707 411 40 water pipe housing 8 $4.14 ($33.12)
996 106 214 70 protective ring 4 $5.13 ($20.52)
999 707 505 40 fuel black o-ring line 1 $4.14
999 707 506 40 fuel beige o-ring line 1 $8.27
999 707 364 41 oil reservoir check valve o-ring 1 $ $1.38
996 106 340 71 water pump gasket 1 $7.46
996 106 326 71 thermostat gasket 1 $2.48
999 707 315 40 water pump housing o-ring 1 $1.38
999 707 468 40 water pump housing o-ring 1 $4.14
900 123 144 30 coolant drain port seal 2 $1.04 ($2.08)
999 701 789 40 oil cooler housing + oil lines to turbo o-ring 8 $0.57 ($4.56)
999 707 422 41 o-ring oil filter bracket 1 $4.14
999 707 426 41 o-ring oil filter bracket insert 1 $4.14
999 707 113 41 oil cooler bracket insert o-ring 1 $2.75
999 701 789 40 oil cooler bracket oil line 1 $1.75
999 707 446 40 oil cooler bracket oil line o-ring 1 $1.38
999 707 409 40 oil cooler o-ring 4 $1.38 ($5.40)
996 107 217 70 oil filter housing gasket 1 $3.74
999 707 298 40 sterling pump housing o-ring 1 $2.75
999 707 204 40 o-ring steering reservoir 1 $5.49
996-106-328-74 coolant hose 1 $27.46
996-106-477-75 water hose supply 1 $17.92
996-106-529-73 coolant hose 1 $6.39
996-106-512-74 water hose 1 $15.64
996-106-250-74 water pump hose 1 $10.34
996-106-233-74 water hose 1 $10.08
997-106-502-00 collant hose 1 $23.88
996-106-501-77 collant hose 1 $24.95
996 106 801 03 o-ring 4 $3.21 ($12.84)
996 106 318 02 throttle gasket : 1 $4.94
996 111 217 70 exhaust ring 2 $23.56 ($47.12)
900 123 152 30 o-ring 2 $0.77 ($1.54)
996 110 318 02 throttle body seal.($6.11)
Coolant pipe fix
Expansion tank
Water pump
Clutch kit w/LWFW
Spark plugs
Water hoses
Fuel filter
Air filter
Crankshaft seal
Boost pressure test
Wastegate adjust
Throttle body seal
Coil packs
Solenoid brackets
Engine mounts (RSS)
Multi-rib belt
Expansion tank
Water pump
Clutch kit w/LWFW
Spark plugs
Water hoses
Fuel filter
Air filter
Crankshaft seal
Boost pressure test
Wastegate adjust
Throttle body seal
Coil packs
Solenoid brackets
Engine mounts (RSS)
Multi-rib belt
