996 Turbo S Clutch Slave Fail - GT2 Conversion or OEM Replacement?
The BBI piece fits into the same location as the stock Turbo slave without modifying the trans case and replacing the clutch forks, and has a bypass for the hydraulic pressure from the PS pump. It looks to be installable with the engine in the car. I believe there are other companies that make a similar soultion using a fabricated mounting bracket for the OE GT2 slave; I have read of potential issues with bracket flex.
The OEM GT2 slave is on the passenger's side of the trans case and requires milling the case flat, drilling & tapping some new holes, replacing the clutch forks, and plugging the original Turbo slave hole. Then either add a bypass for the PS pump or switch to a Tiptronic pump without the clutch pressure output & remove the clutch hydraulic lines. This appears to require an engine out service.
Either way needs the clutch master & lines flushed of Pentosin or replaced.
Yes I got my sides backwards.
The threads about installing the GT2 slave all said that the case surface needed to be machined flat to take the slave - you're saying that is not required?
I haven't done either of these yet.
This. I have the BBI upgrade and its fine once we got it bled properly. Going on 2 years and still love the feel. O do have the GT2 helper spring. It is a must. If I were to do it again though, I would have done the GT2 full drill and tap when I had the trans out. I looked at the BBI conversion as a reversible mod if I didnt like the stiff clutch. Doesnt make much sense now though since I like the feel. Live and learn.
I just had it done and couldn't be happier. I have a turbo s with about 21000 Miles.
I plan on keeping this car for years and the idea of driving around with the ****ty stock clutch feel just didn't sit right with me.
But you don't know what you don't know. If you are good with the clutch operation stock then by all means just replace the slave and accumulator.
If you have ever owned or drove a turbo with the conversion. I don't think you'd give it a second thought.
To me it's that good. Night and day!!!!
Driving with the stock setup made me feel like I couldn't drive a manual. For me the engagement is that unpredictable and without feel.
if ypou pull the rod out of the gt2 slave set it at the edge of the housing you can mark the mounting lug holes. about 1" deep. you can see the outline of the stud boss. center between the studs make a 3/4" hole. done
So, it turns out that the accumulator that was dealer replaced in circa 2015 came loose and was only a few turns away from complete departure. The o-ring was torn in one spot. I ordered a new $25 o-ring and my indy buttoned everything up and it's as good as new.
Thanks for the feedback on the GT2 conversion. I suspect the driving characteristics would appeal to my preferences, but for the 2,000 miles or so that she rolls each year, I'll just have to suffer through life with the stock assisted unit.
100%. i did this years ago and have had zero accumulator issues OR clutch pedal "feel" inconsistencies since. MT porsche's should be started in neutral anyway.
