Idling temp up to 110*C in summer
that makes little/no sense. check your coolant fan- t-stat - water pump or the radiators for pinhole leaks. topping coolant aint gonna do it.
add: my cooling "fluctuation" issue was the result of a fan motor blown. also swapped water pump just prior.
time for some rads
