ABS/PSM Waring Light Question
First of all I want to there has been plenty of responses on previous post about these warning lights in other threads. the shop already replaced the suspected wheel pad sensor and no luck. Checked the battery and alternator and all is well. I need to call them tomorrow and ask them to check and change the MAF and see if that could be the culprit.
However there was something that was brought up to me by the tech. This is what I was told "We were pinning the ABS wiring from the right rear wheel to the ABS and there was an open end at pin 30 at the ABS module." Does this mean there may be a messed up wire on the harness from the ABS sensor to the module? I was also told that when they were tracing the wiring harness they noticed debris and insulation at the body plug which should be there so something may have been in my car. Luckily the car ran fine when these lights came on so I am praying that if there was a rodent involved he didn't do too much damage.
