new clutch for a 2002 996 TT recommendations
So my Clutch started slipping today during a track day and now when I go into the boost the revs climb and the speed stays the same, just managed to drive it home at 65mph
It has a slight tine and has around 500 hp to the crank . looking for something that will be better than stock but to much for street use
But I definatly need nothing a little more durable than the stock clutch
what is the average cost of an indy shop do replace it?
I did mine with my buddy on a rented lift. About 7 hours and all I did was open beer. Yes drop trans only. Woulda been faster but we had to fiddle with the clutch fork upon re-installation. Like 3 times ymmv but that's the trickiest part is lining it up correctly.
Basic Sponsor
We have some friends on CO if you would like to reach out that I can have take care of you. SRE kits in stock too.
Proud TOP Porsche Distributor For:
Kline-Innovation - ams Performance - TiALSPORT/XONA - #1 COBB PRO TUNER - CSF - IPD Plenums - DO88 - dodsonmotorsport
310-600-1850 - sam@bydesignauto.com
If staying with stock flywheel, should it be machined? thinking of going with Sachs 2.5, and was told by a supplier to machine the flywheel for warranty to be valid.
Basic Sponsor
It's a weighted dual mass. Can't machine it. You can scuff the surface to clean it up. Generally the Flywheels are good for several disc or clutch kit replacements...About 100k miles. Unless it was slipped so bad it has hot spots or you can feel excessive chatter. I have shipped over 200 clutches and only changed 10 or so flywheels.
Here are a few options for you to look at..
https://rennlist.com/forums/996-turb...-445-00-a.html
https://rennlist.com/forums/996-turb...lutch-kit.html
Dual Mass clutch kits
https://rennlist.com/forums/996-turb...-595-00-a.html
https://rennlist.com/forums/996-turb...-695-00-a.html
Thanks!
