996 Turbo Forum 1999-2005
A question on fuel injectors...
Old 07-10-2018, 08:29 PM
2fcknfst
2fcknfst's Avatar
Received 3,837 Likes on 2,921 Posts
Default A question on fuel injectors...
As I understand it, the 996tt x50 has 44lb injectors. As my x50 is 15 years old, and I am taking the engine out during the off season, I was thinking about adding a 5 bar fpr as well as a set of these Bosch 0280158117 550cc/52lb/hr injectors; not that I want to make gobs of power, however, I do have a power target of 550/575hp. I am looking at this as a predictive maintenance measure as I will also swap out all the hoses, alternator, water pump, etc.
On other cars I have built in the past, a modest increase in injector volume and adjustable fpr, have done well in meeting the increased fuel demand, along with retaining drive-ability. I was able to trim them (I will do the same thing with the Cobb tuner) to be sure there was always enough fuel, especially under heavy-ish loading.
These Bosch units are quoted as direct replacement, and I am wondering if anyone has had experience with this type of combination.
Cheers,
Old 07-11-2018, 12:43 PM
993GT
993GT's Avatar
keep the stock FPR and do injectors only... some tuners have preferences as to what injectors/size they want installed, worth asking your tuner first
Old 07-11-2018, 01:49 PM
2fcknfst
2fcknfst's Avatar
I will be talking with Sam about tuning the Cobb. So, the stock FPR will provide enough consistent pressure to support a (approx) 25% bigger injector?
Old 07-11-2018, 01:53 PM
32krazy!
32krazy!'s Avatar
leave the stock fpr in the rail and add a set of 1300 cc inj and have your tuner scale the inj. car will run like stock on fuel and handle up to 750 hp with no issues.
Old 07-11-2018, 02:15 PM
SamboTT@ByDesign
Basic Sponsor
SamboTT@ByDesign's Avatar
We should definitely have a chat before you order parts. make a solid plan and path. 1300's are the best and will cover you for good hp as well as factory drivability.
Proud TOP Porsche Distributor For:
Kline-Innovation - ams Performance - TiALSPORT/XONA - #1 COBB PRO TUNER - CSF - IPD Plenums - DO88 - dodsonmotorsport
310-600-1850 - sam@bydesignauto.com
Old 07-11-2018, 02:34 PM
2fcknfst
2fcknfst's Avatar
Yes, I intend to - I am not ordering anything yet, I am learning...
A 1300cc/123lb injector is huge - I do not even have injectors that big on my diesels!!! How is it possible to ever not run rich? Especially under load... wow, that is more than double of what I was thinking would be a good, reliable update.
Old 07-11-2018, 03:16 PM
SamboTT@ByDesign
Basic Sponsor
It’s amazing how smooth we can get them. The car is great and the Cobb tuning software is even greater. They run like factory and the beauty is they run on standard pressure and give you the maximum capacity with the factory pumping and lines. 1000 are also great but they are no longer available that’s why we just go to the 1300. Runs great and they are barely flowing
Old 07-11-2018, 04:33 PM
32krazy!
32krazy!'s Avatar
you can get 1000 cc inj from fid if thats what you want. injector dynamics 1300 cc in j are simply some of the best inj made. not cheap but worth every penny perfect flow match and they seem to pull more power than any other inj. prodigy made 1500 rwhp on id 1700 cc inj on race fuel. 1300 will idle like stock. if theres any oissue it will be the tuners fault not the inj. tony stands behind every inj made. this gives you plenty of headroom for the motor and you will run out of pump before inj. pump is 10x easier to swap than inj with the motor in the car.
Old 07-11-2018, 05:51 PM
2fcknfst
2fcknfst's Avatar
I'm just going for up to 575hp, but those numbers are impressive.
Old 07-11-2018, 05:53 PM
32krazy!
32krazy!'s Avatar
famous last words!!
TexSquirrel (02-01-2023)
Old 07-11-2018, 05:55 PM
nbressette
nbressette's Avatar
FWIW, I run the Siemens 60lb and they work perfectly for those numbers. If you can find a good set on ebay you can get them cleaned / balanced and save some $$ for other mods.
Old 07-11-2018, 06:50 PM
2fcknfst
2fcknfst's Avatar
famous last words!!
I know, I know - I bought an F10M5CP a couple of years ago and swore, up and down, that I wouldn't do anything to it...
710hp and 660ft/lbs later, I have proven myself a liar.
Old 07-11-2018, 06:56 PM
2fcknfst
2fcknfst's Avatar
You know, I was thinking that with the 52lb Bosch units - PN 0280158117 - new updated design, higher resistance under $300USD for a set, direct drop in, and approximately 25% more fuel flow, so that is how a I am leaning. 1300cc monster injectors sound neat, but it is important for an injector to cycle or it gets bunged up. Plus I am pretty solid on my power gains to only go to 575hp.
Old 07-11-2018, 08:32 PM
2fcknfst
2fcknfst's Avatar
The Siemens website is a whole bunch easier to figure out than the Bosch one - with your 60lb units, are they short, mid or long?
Cheers,
Old 07-11-2018, 08:35 PM
nbressette
nbressette's Avatar
https://www.ebay.com/itm/Porsche-996...EAAOxyZw5RbhlY
Same as those, long enough that my fuel rails needed to have a spacer added. The advantage is they use the factory plug so no adapter or modification to the turbo support bracket is required.
edit: just realized thats Sam's auction lol
Quick Reply: A question on fuel injectors...
