996 Turbo Forum 1999-2005
Those that have cut rear fenders (vs rolling)...
Old 07-11-2018, 01:36 PM
  #31
pfbz
pfbz's Avatar
Received 2,718 Likes on 1,461 Posts
Thanks for the tip John!
In the "measure twice, cut once" mindset, verify these are the part we are talking about?
[Update: This is NOT the part we are talking about]
OEM: 996.341.043.06, $219/ea at Sunset
Tarett thrust arm bushing kit
There is an adjustable (TABKA01, $125/ea) and non-adjustable (TABKA02, $100/ea) Tarett bushing. Do we need the adjustable?
Old 07-11-2018, 01:50 PM
  #32
T10Chris
T10Chris's Avatar
The LCA is #21 in that pic, #17 that you have labeled is the thrust arm. The thrust arm bushing is in the control arm.
Old 07-11-2018, 02:04 PM
  #33
pfbz
pfbz's Avatar
OK, looking more it seems that might not be the part John was talking about...
I think it is this one, which PET calls a 'Wishbone' and lists part number 996.341.053.16 (now 996.341.053.17), but Sunset calls a Lower Control Arm. $337 ea. at Sunset.
Old 07-11-2018, 02:10 PM
  #34
pfbz
pfbz's Avatar
This is why I always like to double check descriptions against actual part numbers! My PET diagrams list #17 as "Control Arm" rather than thrust arm, and #21 as "Wishbone", not lower control arm.
Old 07-11-2018, 07:08 PM
  #35
manimal
manimal's Avatar
Yep, thanks for confirming. RL'ers have saved me from ordering the wrong part # more than once.
Old 07-12-2018, 01:12 AM
  #36
powdrhound
powdrhound's Avatar
Received 1,689 Likes on 985 Posts
Paul, the names of a lot of these parts are not accurate in PET or interchangeable with others. Generally this is what you have based on the picture below. These are OEM Porsche Motorsport RSR parts and thus look slightly different from the street parts but you get the idea.
Front toe arms, aka "tie rods"
Front wishbones aka "Lower Control Arms - LCAs"
Rear wishbones aka "Lower Control Arms - LCAs"
Rear toe arms
Rear thrust arms
The items not pictured are the rear upper control arms, aka "dog bones".
[url=https://flic.kr/p/22DLUJk]
Old 07-12-2018, 01:55 AM
  #37
manimal
manimal's Avatar
Thanks!
Easy to see how those bushings are responsible for the fore/aft movement, now, and how some shot ones might allow a lot of it.
We were talking about the rears, but I'm guessing you'd recommend the same thing all around?
Old 07-12-2018, 10:39 PM
  #38
powdrhound
powdrhound's Avatar
Originally Posted by manimal
Thanks!
For a street car I'd just do the rear sold T/A bushings and call it a day. That's where all the weight is. With the solid bushings your rear tire wear will improve substantially.
Old 02-25-2019, 03:39 PM
  #39
HBdirtbag
HBdirtbag's Avatar
btw, finally got under there this weekend while doing a leak test. That tab was all bent up from the tire hitting it. Ground it down pretty good till my dremel attachment decided it wanted to be at a 90 degree angle. So still need to go in and clean it up a bit
Old 05-29-2019, 07:21 PM
  #40
manimal
manimal's Avatar
Bumping this back up as I just ordered new rear LCA's (aka. "wishbones") with Tarrett thrust bushings pressed into them. Thanks again to John and everyone else in this thread for their guidance.
One more question for the experts: while I'm in there, is it worth replacing the thrust arms with something like this? https://www.ecstuning.com/b-european...634104306~eps/ (which replaces the bushing highlighted below)
Here's a vid that makes the sales pitch, but I'm not sure that I'm sold based on this explanation:
Any thoughts? Should I stick with OEM for a street car?
Old 05-29-2019, 07:26 PM
  #41
nbressette
nbressette's Avatar
I'd stick with OEM for a street car. Hard/sporty on a street car is going to get old. This is coming from someone who has the luxury of orange county roads.
Old 05-29-2019, 08:47 PM
  #42
powdrhound
powdrhound's Avatar
The PU bushing is junk. Stick with OEM or the OEM Motorsport Thrust arms. There is no difference in ride quality as both have monoballs on them. The Motorsport arms have offset bushings (see attached picture) to give you anti squat geometry which is nice especially if you are using soft springs as it helps you put the power down coming out of turns. For street use, it really does not matter.
Quick Reply: Those that have cut rear fenders (vs rolling)...
