Cooling failure... light load
Hey everyone,
Went out for a nice after dinner drive to check out my new shifter, exhaust and suspension and I went around a corner and started to accelerate lightly then, poof, white smoke total coolant loss.
It appears to be coming from the left side of the engine, no coolant in the exhaust, but seem to have lost all coolant. 77kms on the clock.... getting it towed to my office and will tear into it.on the weekend.
Thoughts on the failure?
Sorry, correction... right side of engine.
Popped a coolant fitting. Unfortunately, fairly common. There are a ton of threads and ways to fix. Since yours already popped, this may be an engine out fix. Get a list of things to do while its out. Good luck
RangerDick (Nice tag btw...), thank you for the comment - I have read a number of posts on this topic, and I just watched the guy from German Auto(s) video and I see the manifold is right on the back of the engine, whereas my leak (looking the rear) is on the right side. In fact, the left side and back of the engine was pretty dry.
I will lift the back end of the car up and fill it with water and follow the leak... really don't want to take the engine out right now.
Thanks 32Krazy and MDKelly, just my luck! After I located the cooling manifold on the back of the engine yesterday and noted it was pretty dry, I was starting to worry it was on top of the engine.
On the other hand, it gives me the opportunity to pin everything, swap out ALL the rubber hoses and install a new water pump and plenum.
One must always look to the positives, despite how much of a complete **** off that may be.
Upon searching the forum, it would appear that there are 18 hoses on the 996tt that need to be replaced. I found a reference to AWE for silicon hoses, but I cannot find anymore from their website. Are silicon cooling hoses available, or is it better to stick with the factory ones?
i believe that sharkwerks in NorCal also make a replacement "kit" available? anyway... http://sharkwerks.com/porsche/techni...urbo-cars.html
