Do I need a new engine? Hope not! Weird engine noise.
Car: 2004 TT Cabrio - 61k miles.
History: Oil changed 45 miles ago with Mobil 1 TDT 5w40. Been using the same oil for last 4 years. Previous oil changed at 55k miles.
Drove fine after oil change, no issues. Oil level is correct. No leaks.
Last Sunday, I washed the car and put it back in the garage. A week later (todaay), I started to car to go out, I heard this really loud noise (please see video).
It also took couple of seconds longer to start the first couple of times. I shut it off, checked for leaks (none) and started it again. Same noise. Started one more time and took the video.
Oil pressure is fine. No CELs. I have Durametric and I ran the "Short" test. No errors found except the old (P0491 and P0492). Using Durametric, I can activate the Secondary Pumps.
How can tell if it is misfiring? I hope it is not something major... although listening to the sound does not making me happy. I have the Durametric tool, so if I need to log and look at something, please let me know.
It has been very hot here lately but the coolant temperature has been normal. I do idle the car before shutting down for the turbos to cool off.
Please advise/help!!
If all you did was change the oil, and wash the car o don’t think it’ll be something bad. Did you put enough oil in?
The only bad bad thing I saw in the video was the fact that you started the car with the garage door closed
I do hope it is nothing real bad...
About running the car in the closed garage, I ran it only for about 30 seconds.
Update. Jason was right. I started it again and once the high idle fell, it quietened down to normal noise. I went for a 20 min ride and got back home.... oil level and noise level normal.
I also searched for lifter noise and the noise in the videos posted were identical to mine.
Thanks all.... this was the first time I experienced this noise and it freaked me out.
996 TT Weird Noise
996 TT Weird Noise
GL!
KC, I used to own a Boxster before.... Old habits die hard. LOL
RPB81, very true. There are so many threads and videos out there about this.
while everyone is saying its no big deal my 20,000$ built motor had brand new 997 turbo lifters installed. after a 1000 miles one of the flat tappet exhaust lifters failed and broke apart getting torn thru the engine and causing a catastrophic failure. oil pump , pass side scavenger pump, 2 bent valves, 3 scored cylinders and light scoring on the crank . stuck lifters arent to be taken lightly.
I have lifter collapse after 24-36 hours, consistently, Horrendous rattle on startup for 5-6 seconds, then everything is calm. It definitely makes me want to drive daily...
I experienced a stuck lifter on my 993 when I first got the car. Scared the heck out of me and I called the shop to bring it in right away. Halfway to the shop the lifter unstuck itself and all went back to normal. I turned around and went home. 7 years and 40+ track days later and the engine never felt better.
I also get this same lifter noise after every oil change on my motorcycle.
