The Y-pipe is the only mod I have ever felt instantly while driving. The motor is completly transformed, ZERO lag now. It is coupled with EVOMS 3.5" interccolers so huge difference. The boost comes on faster than a light switch.
Are your using the reducers that come with their 3" Y-pipe to connect to the EVOMS ICs or is it a straight 3" setup to the ICs you are running?
Im using the reducers from AP with aluminum inserts. My shop stretched the forge line blue hoses to mate up to the Evoms 3.5 inch IC's. Then coupled that to the AP reducers , then back up to 3 " Y-pipe.
The reduction is only about 2 inches in length.
Understood. Interesting that you saw such a huge response improvement with the 3" pipe. I assumed your IC had 3" outlets and adapters were not used.
