996 Turbo Forum 1999-2005
Transforming TT front axle to GT2 Version
Old 03-08-2018, 02:55 PM
  #31
powdrhound
powdrhound's Avatar
Received 1,723 Likes on 1,003 Posts
Originally Posted by ghostofpain
Hi John,
you know what happens to the bearer of bad news do you?
Thx for the infos, like always precise and accurate.
Hmm, seems like these infos could stop my modding intensions for the front axle, besides brakes.
Will 335/30 in the rear and 245/40 or 255/35 in the front go well together? 255/35 will put more rubber on the ground i guess. Of course RWD mode.
Thx
Keep in mind that tire grip is determined by the size of the contact patch. The larger the contact patch, the greater the grip. There are two ways to increase the size of the contact patch, increased tire width and/or increased tire diameter.
The problem with the 255/35 is that its a much shorter tire than a 245/40. A 255/35 is roughly 24.8-24.9" while a 245/40 is 25.5-25.6". As such, while the width of the 255 is greater, the diameter is substantial shorter which results in a contact patch not much greater than that of the 245/40. In other words, you're not gaining anything. A 275/35 will be about the same height as a 245/40 but will be about 1" wider giving you a much larger contact patch. Now you're getting some grip! Hope that makes sense.
Old 03-08-2018, 02:58 PM
  #32
powdrhound
powdrhound's Avatar
Originally Posted by Oak
thank for the info, it is all coming back to me. haha. yes, I understand the "suspension" points are the same. so I was correct in the oem stock GT2 rotors will not be in the correct position with the stock 6GT calipers on the 6tt carriers. correct?
back then the 997tt was a few years out.... haha
That is correct.
Old 03-08-2018, 03:06 PM
  #33
Oak
Oak's Avatar
Originally Posted by powdrhound
That is correct.
thanks John, I’m old 😂 I’ve been out of it for awhile with the turbo. Time has flown by, I remember back when you started modding and asking me about mods. Now things have reversed. Glad you have continued on and now have brought much insights to the board. Gods speed!
Old 03-08-2018, 03:20 PM
  #34
powdrhound
powdrhound's Avatar
Thanks Oak! Likewise my friend. I didn’t realize you had done the mod back before the 997TT days. The whole re-drill makes sense now.
Old 03-08-2018, 04:37 PM
  #35
ghostofpain
ghostofpain's Avatar
Thx John,
makes sense.
Old 03-09-2018, 12:09 AM
  #36
Slakker
Slakker's Avatar
Just because it's somewhat related to the conversation, here's the 2mm adapter that you can put on a 6GT3/Cup upright to use the TT rotor. But to Oaks point, you can't do it the other way around.
http://www.9products.com/product/279...or-adapter-gt3
As for tires, running the 245/640F 325/680R combination on the car I got from jferrante definitely wanted to push. The rear bar is set to full soft so I think I can dial it out. Interestingly the R888 245/295 combo I ran for a couple of sessions, even though I don't like the R888, did feel pretty balanced.
Old 03-09-2018, 07:13 AM
  #37
ghostofpain
Thx for the hint with the adapter.
I guess i will give the yokohama A052 a try. Seems to be a very potent tire.
Old 03-09-2018, 11:43 PM
  #38
Slakker
Slakker's Avatar
You might check out the RE71R as well. It's insanely good at the track for a street tire.
Old 03-11-2018, 03:13 AM
  #39
ghostofpain
Tires are a hugh problem, not for street use but for road track use. A semi slick needs to be street legal for the car, which most of them are not. Toyo Proxes, yokohama a052 arent streetlegal over here for the 996 Turbo cause of the topspeed. I can use legaly michis cup2 and pirellis trofeo R.
Both sell no 255/35 and 315/30. Iam kind of damned to use 225/40 and 295/30 with awd or 245/40 and 295/30 without awd.
Old 03-12-2018, 11:18 AM
  #40
T10Chris
T10Chris's Avatar
I am guessing NT01 Nittos are also not street legal for you ghostofpain? They serve me very well for driving to the track and back after a day of lapping.
Old 03-12-2018, 03:14 PM
  #41
911mhawk
911mhawk's Avatar
+1 on this, I almost put them on last night just cause we're getting warm today and I'm going to the track Friday and Saturday
Old 03-12-2018, 04:18 PM
  #42
ghostofpain
I dont think you even get NT01 here in europe. So no alternative. Of cource you could drive with yokos or toyos but if something happens..no insurance.
Who knows what happens in this mad world....with all these mad leaders in charge.
Old 03-12-2018, 05:49 PM
  #43
T10Chris
T10Chris's Avatar
Your making me jealous... my engine is sitting on table right now.
Old 03-13-2018, 05:27 PM
  #44
HBdirtbag
HBdirtbag's Avatar
the place where it lines up with the bracket hole
after I posted this, i did a "doh" to myself
Old 03-15-2018, 09:20 AM
  #45
TheDeckMan
TheDeckMan's Avatar
Nice! Looks like another month or so before the snow melts here Look forward to your track videos Mark
Quick Reply: Transforming TT front axle to GT2 Version
