996 Turbo Forum 1999-2005
cheap weight loss
Old 02-10-2018, 02:35 PM
  #61
pfbz
pfbz's Avatar
Received 2,721 Likes on 1,463 Posts
Linking this picture from the thread on engine removal.... Great view of the steel version of the cross brace in place.
Old 02-10-2018, 02:47 PM
  #62
Atrox
Atrox's Avatar
Nobody ever considers the driver for weight loss. Cut out the carbs!
Old 02-10-2018, 09:21 PM
  #63
Dock
Dock's Avatar
Or a driver could just keep the gas tank at or below half full and save ~50 lbs or more versus having a full tank of gas.
Old 02-10-2018, 09:29 PM
  #64
RDS928S
RDS928S's Avatar
Poll; who weighs less than 170 lbs? . Sometimes driver his his worst enemy.
Old 02-10-2018, 10:26 PM
  #65
Sveach756
Sveach756's Avatar
Thats kind of personal don't you think lol
Old 02-11-2018, 01:07 AM
  #66
manimal
manimal's Avatar
My female passengers are < 170 lbs.
Old 02-11-2018, 11:54 AM
  #67
spooltime
spooltime's Avatar
For those into using specified torque values when doing the part swap, please see attached.
Old 02-11-2018, 02:01 PM
  #68
RngTrtl
RngTrtl's Avatar
Great info, Thanks!
Old 02-11-2018, 02:13 PM
  #69
powdrhound
powdrhound's Avatar
Received 1,723 Likes on 1,003 Posts
It's 110Nm for the 4 bolts that attach the crossmember to the side carriers and slightly less at 100Nm for the diagonal brace to crossmember (the TT one is 110 since the bolt is going into steel)
A small legal disclaimer in out litigious society, the TT cross brace is steel due to the portly weight of the 996TT so as with any mods, use the aluminum one at your own peril..
Old 02-11-2018, 02:46 PM
  #70
pfbz
pfbz's Avatar
My Al brace arrived last week... What's everyone's favorite 'kinda grungy cast aluminum' cleaner? No easy access to a blast cabinet.
Old 02-11-2018, 03:40 PM
  #71
TheDeckMan
TheDeckMan's Avatar
Zep 505 works well with a wire brush. Wear a respirator when doing it.
Old 02-11-2018, 03:46 PM
  #72
RDS928S
RDS928S's Avatar
Use this with wire brush then steel wool.
https://www.homedepot.com/p/Citrus-M...2180/202559695
Old 02-11-2018, 04:12 PM
  #73
T Kono
T Kono's Avatar
I'm no engineer, but the Porsche dealer parts lookups show the Turbos needing 997-331-061-00 ($536) - "Turbo W/O GT2", while the 911's get 997-331-261-02 ($200). I'm guessing Porsche is still calling out the steel version for Turbos. The same holds true up through 2008 models. That is as far as I went. Am I paranoid? Seems there must be a reason the steel versions are still shown for the Turbos only.
Old 02-11-2018, 06:58 PM
  #74
RDS928S
RDS928S's Avatar
Powdrhound, do u have one installed on ur car?
Thxs
Old 02-11-2018, 08:15 PM
  #75
pfbz
pfbz's Avatar
No question Porsche had some reason for putting in the steel version, and no one should ever modify their cars in a way their not comfortable with, but it's a bit hard to logically reason why it would be important on a Turbo, but not GT2 and not a 997 C4S...
You frequently see replies in other modification threads along the lines of 'so you think you're smarter than a Porsche engineer?' But Porsche engineers heel to several masters... Cost, regulatory, performance, marketing, etc. and often their choices aren't driven by 'best'.
Quick Reply: cheap weight loss
