cheap weight loss
#31
I got mine for $40 clams from this vendor. Hope it bolts right up- no issues.
https://www.ebay.com/itm/1999-2008-P...53.m2749.l2649
#35
I bought one too... Are we causing a run on alum subframe cross members? :-)
#36
Im going to combine my lightweight rear sub frame install with ebwerks lightweight 996/997 .9 lbs rear wing uprights & get rid of the 15 lbs of rams, oil & hydraulic motor in the deck lid.
Save maybe 20lbs
.Porsche Wing 12-way adjustable Mounts 997 Turbo
Anodize Clear Anodize $319.00 USD Black Anodize $339.00 USD Gunmetal Anodize $339.00 USD Custom Color $339.00 USD Polished Look $339.00 USD Brush Alum. Look $319.00 USD Your choosing color of anodize
Save maybe 20lbs
- Eliminates heavy hydraulic system, this system weights .9lb.
- Much less expensive then the OEM hydraulic system.
- Secure way of holding your wing at very high speeds.
- OEM look.
- Easy installation.
- 12 way adjustable to your liking.
- Extends up to 35mm higher then stock for adjustments needed at the
track - Instructions provided.
- Instructions provided to disable error for wing
failure. - Spanner wrench to remove oem hydraulics from wing, now included.
#38
While were shaving ounces for pennies, you can loose another ~3.5 pounds of weight at maximum rearward moment of inertia on the cheap as well... The first one was $50, for a whole 4'x8' sheet of 1/8" ABS. i guess the next 23 are free.
Rear bumperette delete.
#39
The bumperettes weigh 3.5 lbs.? Are they filled with lead?
#40
Why yes, aren't yours?
Removed 2 high density rubber bumperettes, two alum. support brackets, a few bolts. I was taking the weight estimate from another thread, but the parts are in the garage I'll go weigh them just to be pedantic about it.
#41
Ditch your logo, plate frame and wash car with Dawn to remove any wax.
#43
3 lbs, 11.2 oz. Just a bit less weight savings than changing the brace to aluminum, and farther center of rotation.
#45
