996 intro
996 intro
Hello all. I'm new here and hope this is the place for an intro. Just bought my new to me 2001 996TT, seal gray. Its my 4th Porsche but the first in 7 or 8 years. I had forgotten how amazing these cars are but the 996TT is way different than the others I've had. Of course, I'm learning my lessons early in P car ownership. Literally, on the drive home after buying it the check engine light came on. Bad coil. Replaced all 6 and plugs plus the hydraulic clutch assist (??). Then it snowed twice so it sat for another week. I've had it a month and now it won't start. Key fob won't unlock the doors (put new 2032 battery in it) and, I'll be darned, the key won't go fully into the lock to manually unlock it. I only have one key. So back to Pat W tomorrow. I'm not complaining. I hate i haven't been able to drive it, of course, but the pride of ownership keeps me smiling. Plus, its hard to mile up sittin' in the garage. Anyway. I'm Joe. And hello.
Get yourself a manual if you don't have it. Tons of quirks explained.
Thank you for the reply. I have a manual....its locked inside! Plus the key only inserts about 90% of the way into the cylinder. I've tried 25 times. Its not too cold to freeze. The car is spotless. I can't see any debris in the keyhole. I'm puzzled.
Sounds like something's either wrong with your lock or your key?
You might have to disconnect/reconnect the battery to "wake" the car up so you can open it with the remote. Frunk release cable is routed towards the passenger side behind the wheel liner. Some folks have moved it to behind the tow hook plug. Maybe you will get lucky?
Pull the side marker light out, metal spring clip on the rear molded in plastic lip on front. Get your flashlight and coat-hanger to hook it out.
Worst case remove passenger side front wheel and pull out the push pins that hold the wheel liner and go in from there.
Wheel lock stuck in the frunk/glovebox? You are making this difficult. Get a torx bit or 12 point socket that you can pound over the wheel lock and toss the damn thing when you get it out.
OP welcome back to the 911 platform. I've had many 911's also. but there is nothing like a 500/600 hp 911. nothing "old" or dated anyway enjoy it.
Welcome. Minor setback, though frustrating. Lots of good advice so far... in addition, there is a wire loop behind driver side tail lamp. Force lamp upward while fishing with hooked wire. Grab wire loop and pull, back lid will pop open. Hook up battery charger to + post behind black cap next to oil filter. The ground - to the post at the air box or the latching mechanism. Charge the battery. Hopefully the fob will open it up. But it might not, waiting for the key to be inserted into the door lock and turned. Keep us posted on what finally works.
1. Congrats!
2. That's weird about the key not completely inserting. Anyone around there with curious fingers? (i.e., small children who want to go fro a drive and the popsicle stick doesn't work like a key should)
I got a new battery a year ago and now the car can sit for a month, and still start on the 1st try. I know. I need to drive it more, but so friggin busy.
