Can anyone pull a build sheet?
I have tried the one I have used before but it is not working at the moment.
VIN is WP0AA29954S622814
Much appreciated.
Much appreciated.
Copy paste link add any other vin at end starting where w does
https://admin.porschedealer.com/repo...print.php?vin=WP0AA29954S622814
No problem, the hyperlink will throw you to the rennlist one which in this case pulled up an entirety diff car.
Copy paste the admin part and then manually enter vin at end. The WP with 0 not o always causes issues. Make sure it’s a zero.
You have to copy and past the link above and put in your VIN. Although it is still not working for me. Says car not available. May be my work firewall.
The forum shortens inline url's, so you can't just copy/paste them.
This is the full link for your vehicle that you can copy and paste, then substitute in any vin you want (post 2002)
admin.porschedealer.com/reports/build_sheets/print.php?vin=WP0AA29954S622814
Thought so. Thank you for the full version, works perfectly, really fast too. Anyone know if there is a way to track dealer service records by VIN even though I have no idea where it was serviced? Purely for curiosity.
Cheers
TK
Cheers
TK
But there is no central Porsche database for service by VIN. Each dealer keeps their own records.
There is for Porsche warranty work performed, but most dealers won't share that information with owners. I begged my service advisor to check and learned my car's front center radiator and ignition switch had been repaired under warranty, but neither repair was disclosed on the Carfax even though the dealer that did the warranty work did report "paid" maintenance work performed to Carfax.
