Remove the caliper and tie it off. Lower steering linkage and pinch bolt. Sway bar link. Tape outer fender area for scratches. 3 nuts on top of the hat and mark were they are on the shock tower. The holes are slotted for chamber adjustment. Pry off the coil at the bottom to release pressure. Pull down out and away from the fender. When its outside the fender pull up and out of the spindle. Now the top hat can be removed
